alternator question
Old Jun 13, 2014 | 08:55 PM
vizzual_blur's Avatar
alternator question
On my 03, and likely all, the positive lead goes from battery to alternator, to something further back on the chassis.
what is that? I first thought external regulator but our cars are internally regulated alts?
Old Jun 14, 2014 | 01:46 AM
Anyone?
Old Jun 14, 2014 | 09:50 AM
herrschaft's Avatar
Where on the chassis? Unless you mean the engine which would be the starter.
Old Jun 14, 2014 | 10:01 AM
Its wired to the alt, on the chassis directly behind it maybe 2 feet? Def no starter.
Old Jun 14, 2014 | 10:19 AM
05_SkylineSedan's Avatar
20 Year Member
Here:
http://www.nicoclub.com/FSM/G35/Sedan/2003/
Grab yourself the SC and maybe the PG books and you can read up on the Charging and Power circuits (with big thanks to the NICO Club).
Old Jun 17, 2014 | 07:56 PM
From what I can tell on these terrible pictures, its a starter motor?
Old Jun 18, 2014 | 01:38 AM
20 Year Member
Yes, that's probably what you're looking at. The largest cable from the battery + terminal goes directly to the starter. But the starter takes so much juice to crank that it needs to be switched on by the solenoid which is kind of behind it, closer to the fire-wall. That gets energized and hammers together the really large switch contacts to connect the high-amperage cranking power. Makes sense?
Old Jun 18, 2014 | 06:10 PM
Yea, when someone originally said it was the starter, I was like uhh thats no starter, but a solenoid makes sense. Waitimg for my new 220amp alt now
Old Jun 18, 2014 | 06:13 PM
herrschaft's Avatar
^Technically the starter and the solenoid are considered a single unit.
Machine Head
19 Inch
Mar 16, 2016 08:55 PM
INVADER_6MT
Sep 1, 2015 10:19 PM
Bean_VQ35DE
Aug 22, 2015 09:56 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
