New body harness, and shitty aftermarket security system
Old Jun 14, 2014 | 11:24 PM
Chillichinchill's Avatar
I KNOW THIS IS DETAILED, BUT PLEASE READ!!
Background info (ALL HISTORY ABOUT THE ISSUE): The guy before me installed an aftermarket security system, and also rewired the tail-lights to a button, to bypass a fuse, where he said that the dealership quoted him ($1000) to repair a bad BCM, which I tested and works perfectly, so I am about to finish installing a new body harness, b/c the taillight wire melted, and melted some of the wires around it. When that wire melted, my cars lights interior lights started acting up, also the ABS, VDCL, SLIP, and check engine lights turned on. I got the code pulled, and there was only one that said (bad ECU), so we cleared it and it never came back on, so the ECU should be fine. Also, the car would stall out and burn the ignition fuse when I turn on the tail lights via rewired button. Also, I want to remove the aftermarket security system, b/c the wires are not correctly insulated, which may have caused the short. LASTLY, I noticed my rack and pinion leaking, pretty fast. (My thought is this may have caused the lights to turn on in the cluster and maybe fry my shitty body harness)
QUESTION: After removal of the aftermarket alarm system, and new body harness, am I safe to turn on the car and lights, or should I replace my rack and pinion before I start it, just in case it might have caused the short.
Interested in pictures? (Look here): https://g35driver.com/forums/engine-...-diagrams.html
Hasanbaloch
Feb 29, 2024 08:45 PM
11bEMT
May 27, 2022 03:13 PM
EnCr1pt3d
Jul 8, 2019 02:48 PM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
