overheating i dont know what to do!!!!
Old Aug 29, 2014 | 11:14 AM
ADAMEE3's Avatar
Unhappy overheating i dont know what to do!!!!
Hey all,
I have an 03 g sedan. when i furst bought the car it overgeated a little but i noticed the coolant was low. so added more and it was fine. then about a week late it overheated again but this time i didnt see any coolant low just overfloed into the resivior. so i did the obvious and changed the thermostat then flushed and bleed the system. is was going good untill this morning. driving to work and i look to see im almost all the way to hot. tried turning on the heat and still kept rising. i gave it some gas thinking it might push through my tstat but rose up again. so i pulled over let it sit a few water was rising in my resivoir. but i was late to work so grabbed a towel and just opened the cap took a few tries to get the pressure out and ovcourse this filled my resivior. but i added water and it cooled. so now what????? what is causing this i really dont think its my head gasket. but im stuck now on what elese to do. can anyone helop me out. worried sick about my car
Old Aug 31, 2014 | 10:28 PM
wuzz-upp's Avatar
Does the overheating occur with the AC on and off? Did you check to make sure your cooling fans are both working?
Do a test, when you turn the AC on, both fans should come on immediately.
G35Rican
Jul 31, 2024 01:37 AM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
Jay123
Sep 28, 2015 08:42 PM
yassy
Aug 3, 2015 12:24 AM
joedaddy1
Jul 28, 2015 02:58 PM
