JW how long I can go with....
Old Sep 27, 2014 | 10:46 PM
Hogbone's Avatar
Just curious as to how long should I go with a lean bank 1 code. I just install FI test pipes and I know that is the cause and I'll need to have the A/F ratio tuned. But it will take a few weeks to save up the cash.... Or do the non-fouls sensor correct the problem or do they just trick the ecu so the ses light goes off.
Old Sep 27, 2014 | 11:03 PM
herrschaft's Avatar
Non-foulers will cause the code to go away. Straight pipes won't mess with the AFR enough to "require" a tune, but it is highly recommended for best performance.
KruZZe
Feb 27, 2023 05:04 PM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
gprabhu
19 Inch
Oct 2, 2015 05:55 PM
dcsbh1
Oct 1, 2015 03:15 PM
