Need help! Car shut off while driving to work.
Old Apr 1, 2015 | 11:41 AM
Grandeur's Avatar
I have an 06 6mt coupe. The only mod I have installed on the engine is a ztube and muffler delete. On the way to work I was cruising along at about 40 mph and my car shut off in this order: First the center console/tachometer, then the powersteering and engine. I pulled over to the side of the room and took the key out and went to start it up. Cranked over right away. This leads me to believe that it Isn't my battery but some electrical gremlin😓 I'm taking it in to get my battery and alternator tested but if it's not related (which I doubt it is) I need to figure out how to move forward.
Thanks any help is appreciated!
Old Apr 1, 2015 | 01:22 PM
ScraggleRock's Avatar
Camshaft position sensor
Old Apr 1, 2015 | 02:01 PM
Grandeur's Avatar
What are the symptoms? I would think that the check engine light would have come on
Old Apr 14, 2015 | 01:38 PM
DKatman's Avatar
I felt like I might have had behavior like that after having had some electrical work and it was the connection to the battery.
If so, it was a simple cleaning of the battery terminals and reconnecting the clamps.
I wasn't nearly as smart. It went longer for me than it should have. I would have the car cut itself off in stop and go traffic. It would always start right back up...almost without missing a beat.
It was a very inexpensive fix though. You probably have this fixed by now....although, if it was just once, you may have never isolated the exact problem.
Good Luck,
Dave
Old Jun 2, 2015 | 05:21 PM
DarkLyter's Avatar
Ever get that figured out? And which muffler did u delete, the center muffler?
chinee
Jun 10, 2024 07:48 PM
mike730
Jan 12, 2018 04:25 PM
Joshua615
Aug 31, 2015 12:29 AM
apintojr
Jul 23, 2015 10:52 AM
Tony_Me22
Jul 21, 2015 08:42 AM
