Power Steering Leak - Pictures inside. Please Help.
Old May 30, 2015 | 03:58 PM
garreTT008's Avatar
I've had this leak for about a month now I believe and I'm trying to figure out where it's coming from. I need to top up the fluid maybe once a week if not less, but it's all over the skid plate on the bottom.
I think I have found the problem, maybe you guys can give me some guidance. The leak is on the front passenger side and I've included some pictures of where I think it is. It looks like the one hose clamp is a lot higher than the other and got pushed up by something... or it could be the little piece in the middle of the tubing that could be causing the issue as well.
Let me know what you think.
Old May 30, 2015 | 08:56 PM
garreTT008's Avatar
Old May 30, 2015 | 10:14 PM
Barbatus's Avatar
idk man, it kinda looks like u need a new PS hose. it looks like its leaking right where the clamp is. maybe its not circulating...perhaps when u drive it swells up and leaks..maybe u can cut off that piece where it were normally clamped and re-clamp it
Old May 30, 2015 | 10:31 PM
garreTT008's Avatar
Where could I get power steering hose for the g35? Also is this a high pressure hose? It does look like the hose is in some rough shape...
Old May 30, 2015 | 10:48 PM
Barbatus's Avatar
http://www.autozone.com/suspension-s...sure-line-hose
just insert the year model etc. im sure, u will find something for ur vehicle....
Old May 30, 2015 | 10:50 PM
Barbatus's Avatar
oh damn, i just checked pricing for 2003 auto g35 3.5L for $340sh, thats a lot for it
garreTT008's Avatar
This is all that they have and isn't the hose that I need.
http://www.autozone.com/suspension-s..._238666_19041/
I forgot to mention that this is a 2006 g35 coupe.
Old May 30, 2015 | 10:53 PM
Barbatus's Avatar
ur right, i just looked at it closely... i think u can just buy a hose.. like maybe 1-2 feet hose.. and replace it with ease... its prob like 5-10 bucks. they normally have a roll. and just cut u off a piece
Old May 30, 2015 | 10:55 PM
Barbatus's Avatar
http://www.autozone.com/suspension-s...se/209593_0_0/
Old May 30, 2015 | 10:57 PM
Barbatus's Avatar
thats like 3 feet for that hose... im sure u can fix both of em, and have extra for other stuff u may wanna replace
Old May 30, 2015 | 11:29 PM
garreTT008's Avatar
Right but what's the plastic part inbetween? It goes from a larger hose to a smaller hose and clamps onto a piece near the front. It transfers from larger to smaller? Is it under a large amount of pressure? Is there anything that I should be worried about?
Old May 30, 2015 | 11:31 PM
bigc's Avatar
Wings Nation
I recommend that you use a pair of pliers to release that clamp, push the hose further onto the nipple/hard pipe, then clamp the hose back down. Clean the area thoroughly and keep an eye out for signs of continued leaking. Its hard to tell where a leak is coming from if you don't keep things clean.
Also, please don't create multiple threads on the same topic.
Old May 30, 2015 | 11:37 PM
garreTT008's Avatar
That's a good idea, I'll try that first. Thank you.
I think I posted this in the wrong section, so I reposted in another where I thought it was more appropriate, I apologize.
How would you clean this off? Engine degreaser? It seems to be extremely oily and difficult to clean.
Thank you both for your help.
Old May 30, 2015 | 11:43 PM
bigc's Avatar
Wings Nation
No worries. Some folks use simple green to cut through the grease, but soapy water and elbow grease are really all that you need.
Old May 30, 2015 | 11:59 PM
garreTT008's Avatar
Okay I'll try this out tomorrow and report back the results.
Thank you both once again.
bu villain
Accessories
63
Aug 25, 2016 07:14 PM
joedaddy1
Jul 28, 2015 02:58 PM
newg37
Jul 26, 2015 09:32 AM
