04 G35 Coupe electrical issue
Old Jun 11, 2015 | 06:27 PM
Nick6315's Avatar
Hello,
I am new here and apologize if I am duplicating a thread.
A few days ago my car started having a new issue where when I would depress the clutch and put in the key, as soon as I ticked it forward once it would disable all the power and the entire car would be dead. I would then have to go through the process of removing the negative battery cable and putting it back on until power was restored to the car and then hope it would work the next time. This usually takes between 5 and 10 times of repeating that process, along with engaging and disengaging the alarm before the car starts, and then occasionally the RPMs drop low enough for the car to shut off. I spoke with an Infiniti maintenance friend of mine who suggested it may be the negative connector and that I replace that, I was wondering if anyone else has suggestions on what else could be creating this issue.
On a completely unrelated note, is the AC Condensor located above the dummy pedal in a 6Mt, bc I occasionally get water on my foot after driving for an hour plus with the AC on.
Thanks for all the help you guys and have a great evening!
arora_g35
Apr 16, 2026 02:52 PM
rezendvous420
May 31, 2020 01:26 PM
ClwMike
Jul 23, 2015 12:55 PM
justgotg35
Jul 19, 2015 12:33 PM
