engine stand
Old Jun 14, 2015 | 05:17 PM
lilsLb88's Avatar
engine stand
I'm going to be putting a stick vq35de long block from a g35 on an engine stand but I was hoping someone could tell me what bolt sizes I'll need to go through the stand and into the engine. I've searched but can't seem to find this information anywhere. Thanks
Old Jun 30, 2022 | 10:05 PM
jibberish89's Avatar
Slightly modified
Does anyone know the answer to this?
Can't find the answe anywhere
Old Jul 2, 2022 | 09:23 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
I just use allthread and cut it to length. It's going to depend on YOUR engine stand since the length of the stubby pipe section varies from stand to stand.
Most of my stands I end up cutting those stubs off with a portaband, then making my own from 1/2" EMT since sometimes I need the engine closer or further from the stand depending on if it's still got a flex plate/flywheel installed, or if I want to just use the bellhousing bolts to attach it to the stand, etc.
lilsLb88
Jun 14, 2015 07:51 PM
xfatboi
Mar 31, 2011 05:51 PM
G3.5-Unit
Nov 27, 2008 11:59 AM
