Drivers side window is not secure. Don't know whats up.
Old Jul 17, 2015 | 12:35 AM
will091195's Avatar
Okay guys, so my G was perfecty fine, and then my door lock actuator failed. I wanted to see just how bad it would be to replace it, so I pulled the door panel, and then pulled the metal plate behind the door panel so that I could look in and see the actuator. I then put this plate on, making sure to secure the window motor assembly back to this plate. However, when I closed my door I noticed that my window wasn't aligning right. I then also noticed that when I grabbed the window more towards the front of the car, I could pull it up or down about an inch, but no more.
I double checked to make sure it wasn't the bolts loose, nothing there. So I have no idea what it could it be. I'm praying I didn't some how damage the power window assembly. Any ideas?
Old Jul 27, 2015 | 09:19 PM
muhtish's Avatar
I had to work on my windows in the past. It is a two man job, out should I say, it is much easier with two people. The window is adjustable! Which I didn't take into consideration from the get go. Thus it took me several times of taking the door apart and adjusting bolts to make the window align to part. I wish I could help out more, but it has been awhile since I messed with my windows.
mbe093
Lights
Oct 2, 2016 11:09 PM
Ludz
Lights
Mar 28, 2016 02:06 AM
apintojr
Jul 23, 2015 10:52 AM
vstypicals
Jul 20, 2015 10:55 PM
