2005 coupe struggles to start
Old Aug 30, 2015 | 03:15 PM
junon's Avatar
Hi everyone,
I'm experiencing some issues with my 2005 G35 Coupe (A/T) 115,000 miles. I've already searched and dug through the forums for as many possible causes to my issue and have begun trouble shooting, I'm writing this post in hopes that I don't miss a simple symptom or cause.
My car does not start easily, I turn the ignition and it takes several seconds, sometimes ten for it to finally turn over and spring to life.
Things I've already done:
-Fuel pump is fairly new, only been in the car for ~7,000 miles, secondary fuel level sensor replaced at the same time.
-Brand new battery just swapped in, had it checked to make sure it's not defective
-New Spark plugs put in at 100,000 miles
-Removed the MAF and cleaned it properly using MAF cleaner
Things I have yet to check/try:
-Fuel Pump Relay
-Crank Position Sensor
-Camshaft Sensors
-Clean the Throttle Body
Is there any other likely culprit that I may be missing?
-No error codes, not even pending
-Idle RPMS are perfectly normal and within spec
-Engine temp sits right at the halfway mark once warmed up and never fluctuates
Other issues I've been experiencing include a radiator which is clearly at the end of its life, already ordered a replacement and will have that installed as soon as it arrives; and an ongoing issue with my fuel gauge not always being accurate (was worse before I replaced the fuel pump).
Thanks for any help!
Old Aug 30, 2015 | 11:40 PM
coffeysm's Avatar
Originally Posted by junon
Hi everyone,
-Fuel Pump Relay
-Camshaft Sensors
Starter or starter relay?
Old Aug 31, 2015 | 07:14 AM
VenomGT9's Avatar
Bingo
Old Jan 14, 2023 | 04:58 PM
jk319's Avatar
Infiniti G35 Sedan Automatic no mods
I got mine fixed by shipping the cluster to rapid electronics on ebay. I think they soldered the circuit board.
Old Jan 14, 2023 | 09:37 PM
Urbanengineer's Avatar
Same issue with the car I bought. Starter solenoid craps out and then it won’t engage. Eventually it will skip and sound like crap.
Tannerwood2k1
12
Aug 12, 2023 11:38 AM
VWownerwith1.8
Jul 22, 2022 11:01 AM
Alfonso951
May 10, 2021 11:41 AM
yosip1115
Mar 25, 2013 08:43 PM
VRTMattG35
42
May 6, 2012 10:56 PM
