Factory radiator differences, 2 different part numbers
Old Sep 23, 2016 | 03:20 PM
Swaglife81's Avatar
So I'm currently in the process of my 03.5 Sedan partial restore. A few things aren't working to well. Clutch fan is shot and A/C condenser fan (Pusher fan) isn't coming on at all. Since the I'm upgrading to Electric Fans and I'm gonna have everything out anyway replacing thermostat and so on I figured with how cheap radiators are I might as well while I'm there.
The parts catalogs online show 2 radiators for 2003
Infiniti Part No.: 21460AM900
RADIATOR ASMY
This part fits the following vehicle options:
Production Date: 08/2002-08/2004
Fitting Vehicle Options: *S. 2WD. VQ35DE. TRACK. AT. F5 + *S. VQ35DE. BASIC, *S. VQ35DE. AT. F5, C. VQ35DE. AT. F5, C. VQ35DE. AT. F5 + 4WD. VQ35DE
And
Infiniti Part No.: 21460AQ800
RADIATOR ASMY
Production Date: 01/2002-08/2004
Fitting Vehicle Options: S. 2WD. VQ35DE. TRACK. AT. F5 + S. VQ35DE. BASIC, S. VQ35DE. AT. F5, VQ35DE
In any description I see these radiators say will work with manual and lists for at and so on. It also says even manual guys will see it has a at cooler but its ok if its unused.
I have a 2003.5 Sedan at5 and again going electric fans. Is the only difference fan shroud mounts? FYI 03 Sedans had a mechanical fan, some even 1 single electric fan and coupes had dual electric fans. I just want the best sized factory type radiator that will fit a 03.5 premium sport packaged Sedan AT5
Old Sep 25, 2016 | 11:13 PM
Target350z's Avatar
G35 sedan 6 spd
I would think 21460AM900 wouldn't work? I could be very wrong here. I'm looking to buy a 21460AM900 radiator ( 2003 or 2004 6spd sedan) . How much are you finding 21460AM900 for by way?
Old Sep 25, 2016 | 11:28 PM
Swaglife81's Avatar
RockAuto $40-$90 and about 8 different radiators to choose from. Specs are listed for each and they all seem to be the samr
Old Sep 29, 2016 | 09:35 PM
saywat?'s Avatar
all i know is theres a rad for autos and a different rad for manuals
Old Sep 29, 2016 | 10:39 PM
ScraggleRock's Avatar
The only difference is that an MT specific read won't have the nipples for the auto trans lines. V most companies just make a universal one cuz it's cheaper, so they'll put the nipples on it, but if you don't use them, they don't do anything.
Old Oct 3, 2016 | 05:52 PM
Swaglife81's Avatar
The only other difference I saw is the manual version radiator is 28 inches wide and the auto is 27 inches. And each can be used on either
Old Jul 21, 2020 | 06:13 PM
DRIFTLY's Avatar
2003 G35 Sedan aka - “DRIFTLY”
You’re forgetting something.
I have a 2003 Auto Sedan non sport models.
these cars came with: “CLUTCH FANS!”
Not the dual electric fan set up like the “Sport models did, ie the manual/Brembo cars.
ive been trying to find stock replacements and have bad luck in the states.
they only made these car setups for 8 months then decided to just go with all the cars having dual electric fans 04 and beyond no matter the trim model of the car.
so these parts are so rare in the states that a company was going to charge me $230 for the “Fan Blade”!!! That’s not including the clutch!!! I don’t need the clutch regardless. But wow.
I ended up ordering overseas from Dubai, part was like $53 (JDM Genuine Nissan part) and then $40 for shipping and will be here tomorrow. I ordered it on Sunday and it’ll be here tomorrow!!
now just need to hunt down a fan shroud.
hope this help guys!!
-DRIFTLY
