Aftermarket Fuel pump!
Old Jun 29, 2017 | 08:18 AM
socalg35x's Avatar
Hi guys,
will greatly appreciate if anyone can share a aftermarket fuel pump assembly p/n for 2005 g35x sedan...everything on rock auto is for coupes only. I believe the equivalent Infiniti p/n is 17042AC700.
Thanks a million!
Old Jun 29, 2017 | 05:33 PM
socalg35x's Avatar
Bumpy
Old Jun 29, 2017 | 05:35 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
You sure it's not the same? Powertrain is the same so I don't see why the pump would be different.
Old Jun 29, 2017 | 05:38 PM
cleric670's Avatar
BANNED!!!
Well looks like I was wrong, they ARE different pumps.
http://www.infinitipartsonline.com/auto-parts/2005/infiniti/g35/x-trim/3-5l-v6-gas-engine/fuel-system-cat/fuel-system-components-scat
Coupe is at top, sedan is at bottom.
Old Jun 29, 2017 | 06:15 PM
socalg35x's Avatar
Thanks. Yes they are different. Any suggestions for a good parts store to find an aftermarket part
Old Jun 29, 2017 | 08:27 PM
cleric670's Avatar
BANNED!!!
http://www.importpartspro.com/fuelcomponents6.html
Walbro and Deatchwerks are the only two pumps I've ever read anything about, N/A application I'd go with the Walbro (actually if the engine was N/A I'd just stick with the stock pump but w/e...).
Old Jun 30, 2017 | 09:36 AM
Urbanengineer's Avatar
Wal bro for aftermarket fuel pumps only. Had great quality from their stuff in all our cars, street or track.
Old Jul 7, 2017 | 09:42 PM
Swaglife81's Avatar
Not sure if you figured out your scenario yet. What are you looking under in Rock Auto. All the fuel pumps are listed as 4 door sedan under 2005 G35.
Delphi FE0351 - $48
Airtex E8335 - $45
Autobest HP4346 (This is listed as a high performance replacement over there standard fuel pump
There are 2 other fuel pumps for like $25 listed as their economy pumps. Back in the day I used Walbro 255 a few times in Mustangs and those damn things were whinny.
Old Jul 8, 2017 | 01:09 PM
socalg35x's Avatar
Ended up getting Delphi fe0351 from auto zone. A word of caution. The rubber grommet that sits on the fuel pump outlet was cracked for me so I had to order OEM part since autozone doesn't have something like it. So y'all might as well order it before hand before you remove the fuel pump assembly. The part number is 17044-4m405... costs $6.88.
anyone has any questions regarding this, don't hesitate to contact.
