g35 brakes question
Old Jan 7, 2018 | 06:37 PM
underworld's Avatar
g35 brakes question
can someone clarify for me if the brake calipers on the 2005 infiniti g35 coupe bolt on directly to a 2004 infiniti g35 coupe and if I can use the same pads and rotors on the 2004 infiniti with the 2005 calipers (just regular brake calipers NOT brembo calipers)
Old Jan 7, 2018 | 08:47 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Rotors and calipers are matched to each other and you cannot mix/match. The options are brembo, older caliper, newer caliper for OEM stuff.
BJD275
May 21, 2009 09:26 PM
elrooko
Canada
Jul 15, 2006 10:54 AM
IS300TOG35
Mar 17, 2005 11:36 AM
