2008 G35x overheating
Old Feb 7, 2018 | 11:55 PM
LadyG35x's Avatar
Symptoms:
Overheating when driving only not when idle. Does not get all the way to the H, but the thick line before it.
was told there were no leaks
Did not smoke / steam when it was overheating
heat still works and brings it down to just a little above normal when heat is on full blast and highest it can go (90)
no coolant smells
no check engine light
still drives the same the last time I drove it. I drove it to a shop about 10-12 mins from my house, It did not overheat. The shop sit and let it run idle. As soon as I drove off it started over heating. I was told ot was a thermostat due to one hose being cold and other hot. However later I found out this shop has bad reviews on google so now Im nervous. Does this sound like a thermostat issue to you all?
Old Feb 8, 2018 | 07:22 AM
telcoman's Avatar
Veteran: Army
Originally Posted by LadyG35x
Symptoms:
no coolant smells
LadyG35X
Here is my $.02
My advice to you is make an appointment at your local Infiniti dealer and request a loaner vehicle.
Even before you make a service appointment visit the sales department and drive a new vehicle that comes with all new parts and a warranty. Get a price and inquire what they will give you on a trade in. Don't mention the overheating problems.
Suppose the repair totals $1000.00 Spending that amount of money on a ten year old vehicle is not going to make it worth more if something else fails a month later.
Yes the dealer repair labor rate may be higher than local shops but you've got a better chance of getting your vehicle fixed properly.
You may need a thermostat, a new radiator cap, possibly a new water pump, coolant flush, new radiator hoses, and even possibly a new radiator if your is clogged.
You didn't mention the mileage on your vehicle
http://www.nicoclub.com/service-manu.../Sedan/2008/CO
See page CO-03
If you don't have a significant other who knows about vehicle repairs you need to be very very careful on which shops you can trust.
Driving a new vehicle with a warranty is much safer for a female that knows little about vehicle repairs
Good luck to you
Telcoman
Old Feb 8, 2018 | 08:57 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
It can be a lot cheaper in the long run as well since repairs can quickly exceed $1k and that's about 5% of the cost of a new vehicle for a repair of a SINGLE issue.
Old Feb 8, 2018 | 10:47 AM
cleric670's Avatar
BANNED!!!
You should wait till the engine is cold and remove the radiator cap to verify it's NOT just low on coolant. Don't just assume that the reservoir being full means it has coolant. The thermostat is a common point of failure on every vehicle so it is definitely possible it is failing.
Old Feb 8, 2018 | 08:38 PM
LadyG35x's Avatar
Originally Posted by telcoman
LadyG35X
Here is my $.02
See page CO-03
Good luck to you
Telcoman
Thank you so much! I couldn't wait anymore (been without my car since Fri) I took it into some place else, they said the same thing about the thermostat. I got replaced and a system bleed and it seems fine now.
Old Feb 8, 2018 | 08:40 PM
LadyG35x's Avatar
Thank you...! I couldn't wait anymore (been without my car since Fri) I took it into some place else, they said the same thing about the thermostat. I got replaced and a system bleed and it seems fine now.
Old Feb 9, 2018 | 03:57 PM
cleric670's Avatar
BANNED!!!
Awesome, glad you're up and running again.
Old Feb 10, 2018 | 04:05 AM
LadyG35x's Avatar
Thank you!
Old Sep 30, 2019 | 12:45 PM
MikeG35Coupe's Avatar
20 Year Member
One owner 2004 G35 Coupe 6MT
Reported to mods.
Amy24
Oct 7, 2015 05:01 PM
apintojr
Aug 12, 2014 06:02 PM
JustinMKN1
Apr 23, 2014 08:39 PM
adlee3
Feb 24, 2010 09:03 AM
