G35 won’t start at all
Old Oct 12, 2018 | 12:27 PM
Mustafa's Avatar
G35 sedan 6MT
Hey guys sorry if something similar has been posted before I’m new to the forum, so I recently picked up a 2005 G35 sedan 6MT with 206,000 and the car drove home fine when I picked it up, and after that as well but I noticed later that day it was taking long to start, when it started it drove good just this one time the engine smoothly cut off, no shudder or anything I didn’t even realize the car was off but it turned on right away, it turned off in neutral, but then I parked the car for 5 days due to weather and when I tried starting it it wouldn’t start at all, it started once but turned off shortly after. We tried jump starting it, everything. No start. And if it does start by any chance it’ll turn off soon. It had two check engine codes when I bought it and it still has them but I don’t think those have anything to do with the starting and running ability for the car, it has a P0456 and a P0507, for high idle and small EVAP leak. I’m assuming it’s either a crankshaft sensor or cam sensors? But wouldn’t it throw a code for that? Any help would be appreciated.
Old Oct 12, 2018 | 09:17 PM
cswlightning's Avatar
Could be all sorts of things with that kind of mileage. If I were you I'd pull the spark plugs, check compression first just to make sure it's worth the effort. If that's all good, replace the plugs, check for vacuum leaks as that can cause high idle. I would also clean the MAF and throttle body while it's all apart, make sure you don't move the throttle body plate unless you're a gambler. Google it if you don't know how to do these things, they're all easy and can be done in an hour or two.
My car had a similar problem with hard starting recently which turned out to be the coolant temperature sensor going out, but that also caused the temp gauge to indicate overheating - but I'd replace that too for $6 just for peace of mind and to be sure. At that mileage, if the crank/cam sensors are original they're going to break eventually, so replacing them might not be a bad idea.
If that doesn't fix your problem I have no idea, but I'm not an expert on these cars. Hopefully someone else will chime in after you've checked the basics.
Old Oct 12, 2018 | 10:08 PM
Mustafa's Avatar
G35 sedan 6MT
forgot to mention car is in KM, and when your car had the coolant sensor issue did it stall at low idle? And my car isn’t starting at all, and crankshaft sensors are pretty expensive so I’m really hoping those fix the issue, although there’s no engine code for it I’m experiencing the exact same symptoms as other people with bad crank sensors. Just want to get it working again.
Old Oct 13, 2018 | 09:44 AM
telcoman's Avatar
Veteran: Army
A almost fourteen year old vehicle with 128k miles is not a super high mileage vehicle, however was this a garaged vehicle or when left outside in all kinds of weather?
If it were mine prior to spending money for any needed repairs I would have the vehicle thoroughly inspected by an Infiniti dealer to give you a service, recall history and have them run the VIN number.
I would be concerned about the suspension, brakes, tires, exhaust system and all of the electrical sensors and components.
Many have posted that buying cheap non OEM parts do not play well and usually result in wasting money and buying twice.
If you are planning to do most repairs yourself you should probably obtain a copy of the FSM and follow the troubleshooting steps.
Good luck
Telcoman
Old Oct 13, 2018 | 10:02 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
The typical cause for that EVAP low leak code is not properly installing the gas cap, are you using the OEM gas cap or is there a different replacement cap installed, make sure you screw it down until it clicks.
The high idle code is most commonly caused by a vacuum leak, remove and inspect the intake piping, pay particular attention to the flexible section and where the clamps are installed. Next remove the PCV valve (it's threaded so unscrew it) and shake it to make sure it rattles and the valve isn't stuck, also inspect the hoses going to both valve covers and the transfer hose that connects the two valve covers together at the front of the motor.
If everything looks good then I would remove the crank sensor (CKP) and inspect it for any obvious damage INCLUDING oil contamination of the harness, use electrical contact cleaner like CRC red can (never use CRC blue can contact cleaner on cars it dissolves plastic, you can use CRC green can contact cleaner if you don't wear safety gloves and it will save your liver from some of the chlorine in the red can) to clean the harness AND the sensor plug. If everything looks good on the CKP sensor then remove/inspect/clean all 4 of your cam sensors (CMP) using the same procedure.
Since you're throwing an EVAP leak code as well as a high idle which normally means an intake leak my gut feeling is you don't have a sensor problem but rather just have leaks, I'd pay particular attention to the passenger side of the motor near the firewall where the EVAP purge solenoid is located, you might have some obvious damage to the engine in that location.
Old Oct 13, 2018 | 01:57 PM
Mustafa's Avatar
G35 sedan 6MT
would an EVAP leak or a vacuum leak cause the car to not start? The car does turn over and even sputter but it won’t go past that. This one time it did and it shut off shortly after. And I don’t know much about the cars history as I bought it from an auction And yeah the OBD did say something about the purge solenoid but isn’t that back by the fuel pump? Thanks.
Old Oct 13, 2018 | 01:59 PM
Mustafa's Avatar
G35 sedan 6MT
Good luck
Telcoman
yeah I would but the car doesn’t run or move at all, pretty bummed because I only got to drive it for like a combined 20 minutes.
Old Oct 13, 2018 | 04:10 PM
Sounds like the PO sold you a broken car. Maybe you could ask him to at least have the courtesy to tell you what's wrong with it/what he's already replaced/checked. When you know the owner was cheaping out on things everything on the car becomes questionable - is that "new" sensor actually good, or is it a **** aftermarket part which could be causing issues?
Old Oct 13, 2018 | 04:39 PM
cleric670's Avatar
BANNED!!!
I know it seems obvious but the number 1 reason for the car stalling and not sputtering is simply running out of fuel, the gas gauge is notorious for failing and displaying the wrong amount of fuel so I would add 1 gallon and try to start it again.
Personally I like to rule out other items before diving into replacing the CKP because it's about $100 for the OEM sensor, unfortunately fuel pressure isn't easy to test because there's no factory fuel test port, Z1 Motorsports sells a sandwich adapter for the passenger side fuel damper so you can add one.
Spark can be tested by pulling the fuel pump relay out, crank the engine a couple times to relieve fuel pressure, take out a spark plugs and, plug it back into the coil pack, hold the coil pack with a leather gloves hand and keep the groun strap of the spark plug within 1/4" of the intake manifold while someone else cranks the motor and you watch for spark.
If you have spark and fuel pressure THEN I would replace the CKP. If you replace it and it still doesn't run properly buy one of each kinds of CMP, one straight connector and one angled, identify the new ones with a sharpie or paint pen so they're not confused with the old ones. Replace them with the old ones on one bank, if it's still not running swap them with the 2 on the second bank.
Or you can pay Nissan for a diagnostic, they have access to the tools needed to actually TEST those sensors (unless you know someone with an oscilloscope) so you don't end up replacing a bunch of components that aren't actually bad.
Old Oct 14, 2018 | 02:48 AM
Mustafa's Avatar
G35 sedan 6MT
I bought it at an auction the owner came up to me while I was checking the car out and told me all about it trying to make it sound better, he said it had an exedy clutch on it and he never really drove it apparently. It’s been days and the cars been sitting in my garage. Just trying to get it running again.
Old Oct 14, 2018 | 02:49 AM
Mustafa's Avatar
G35 sedan 6MT
what I recently just thought if is when I boosted it it did take a long start to start but it did start, and I took the cables off and shortly after it died, so could this be a battery problem?
Old Oct 14, 2018 | 11:49 AM
cleric670's Avatar
BANNED!!!
Or the cable connections where they are attached to the battery post could be severely corroded and your jumper cables were attached to the OUTSIDE of that connection. Take them off, wire brush clean, apply electrical anti-oxidation grease (not dielectric grease), charge the battery, reattach and try again when the battery is full.
Old Oct 14, 2018 | 01:32 PM
Mustafa's Avatar
G35 sedan 6MT
engine just cranks faster. No start. It does sound like it’s going to start, but it dies off.
Old Oct 14, 2018 | 01:44 PM
telcoman's Avatar
Veteran: Army
Is there enough gas in the tank?
Check fuel pump pressure
Check for spark
Telcoman
Old Oct 14, 2018 | 01:54 PM
I'm guessing fuel pump combined with a massive vacuum leak but you need to start troubleshooting and bringing in some more information - at this point we're just guessing as much as you based on our personal experiences with similar issues.
