Ac display not working, SRS light on
Old Oct 15, 2018 | 01:08 AM
Kyle Landrith's Avatar
Sedan 5AT
So I got a JDM clock/AC display. Plugged it in, worked fine. Took it out to swap the clock over to US spec display. Went for a drive to airports store for some things without the display in. SRS light came on. Got home and swapped in the clock and a display. Clock didn't work and neither did the AC controls. Disconnected battery to reset everything, still a no go. I'll check fuses tomorrow as it's late now, and go through the procedure to reset the SRS system. Tried the JDM board, still a no go. Any ideas? Gotta get this fixed. Also, any idea on wiring the jam clock up? The wiring diagram I found on here didn't work...
apexi957
Aug 5, 2011 04:35 PM
johnhk79
Nov 10, 2010 12:33 PM
mellinox
Aug 8, 2010 06:16 PM
