Rat ate my wires! Help locate wire position.
Old Mar 8, 2019 | 03:35 PM
veprdude's Avatar
Red Sedan w Electric Fans!
Long time lurker... Finally joined.
So while tracking down why my AC compressor won't turn on, I found a bunch of chewed up wires by my IPDM on the passenger side fender. On the 3 connector bank, the rearmost connector has chewed up wires. Easy enough fix except 2 of the wires are the same color and I can't tell which goes where since the wire is nibbled all the way down to the connector. I was able to trace one of the orange wires to the backup light relay. No continuity exists between the 2 orange wires. I can't tell if they are related. Anyone have a detailed wiring diagram?
Thanks!
Old Mar 9, 2019 | 11:03 AM
G2B35AGN's Avatar
What year? I have 2006 sedan and coupe FSMs I could extract diagrams from.
Old Mar 9, 2019 | 12:43 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
There are colored dots on each orange wire, they are a different color.
You can also find the full wiring diagram inside the FSM, section PG Power and Grounding.
https://nicoclub.com/archives/infini...e-manuals.html
Old Mar 9, 2019 | 09:36 PM
veprdude's Avatar
Sorry. 2003 Sedan. It was one of the ones with the factory clutch fan if that helps. As far as the dots on the wires, they look the same to me but regardless, they are chewed down to the connector and maybe 1mm of wire exposed. All I can tell is that they were orange.
I was able to trace one of the orange wires to the back up light relay. Don't know where the other goes. Ran a continuity test and no continuity when the vehicle is off. When running there is continuity on the chewed side, but never continuity on the other side.
Old Mar 10, 2019 | 01:56 PM
cleric670's Avatar
BANNED!!!
Section LT page 135
Old Mar 11, 2019 | 11:45 PM
veprdude's Avatar
Issue is fixed. Pin 4 Orange Wire is AC Pressure Sensor. Pin 5 Orange is Backup Light Relay. Backup lights and Compressor work now.
d_16_85
Feb 7, 2012 11:29 AM
Choleaoum
Mar 8, 2011 10:24 PM
kingrukus
Jun 19, 2008 11:11 AM
Christopher____
V36 General Tech Questions
May 16, 2008 10:11 AM
Christopher____
May 15, 2008 05:27 PM
