GPS screen
Old Jan 16, 2020 | 12:47 PM
Tjacca's Avatar
I have a G35 coupe and it drive prefect besides the bad rear shocks
GPS screen
Ok, I’m new to this forum.
I recently bought an oem navigation screen for my 2004 g35( which already support the navigation system)
but when I plug in everything the screen doesn’t turn on but I can hear the DVD player running so I think it’s something with the wiring of the screen but I have no idea and I need some helppp
Old Jan 16, 2020 | 05:51 PM
Scorpi0's Avatar
What happened with your old screen?
And why are u installing OEM navi?? That śhit is older than Pelosi.
Old Jan 16, 2020 | 05:55 PM
Tjacca's Avatar
The navigation screen was gone when I bought the car. Everything else was there it just doesn’t look right with a big ol gap right there
Old Jan 16, 2020 | 06:15 PM
telcoman's Avatar
Veteran: Army
Use WAZE or Google Maps
Much better than OEM Nav
Old Jan 16, 2020 | 09:46 PM
Scorpi0's Avatar
I wonder if u could remove the navi and install a cubby in there with a cover.
Old Jan 16, 2020 | 11:50 PM
G2B35AGN's Avatar
You'd also have to get the non-nav radio faceplate.
Old Jan 16, 2020 | 11:57 PM
Tjacca's Avatar
that’s how it was when I bought it but the previous owner didn’t do a really good job so it ended up looking bad
but I am thinking about replacing the navi screen with a tablet.
Old Jan 18, 2020 | 10:48 AM
Ryan_vq35's Avatar
G35 Sport/Premium Package 5AT
Confirmed, did it with mine. I really like having the extra storage space to put my phone or wallet inside while driving. Don't forget to remove the Nav DVD drive and get the glovebox insert to replace it for even more storage! (but don't expect much) I have one sitting in my closet waiting to be installed on my car so let me know if you need part number. If you are planning to do this just know that the brackets for nav and non nav radios are NOT the same. I found this out after I got the job done and now I have a gap that looks like this...
So before you do this, make sure you acquire the radio brackets from a non nav G radio. It looks this way because I believe my installer guy had to drill holes in my original bracket since the holes didn't line up right. I remember having the part number saved somewhere but can't find it right now. I had to end up buying an entire radio assembly on ebay for just the brackets. So you're best bet would be looking for junkyard G's and see if they will part with just the brackets... (most don't want to would rather sell the whole unit)
Old Jan 27, 2020 | 11:14 PM
TokkioDrift's Avatar
04 6mt Coupe - motordyne 5/16 ART pipes TDX2; KWv2; Hotchkiss; custom seats.
I guess the radio bracket is different on the 05-07 radio with nav. On my 04 with nav, I just took the screen out and nav buttons off 2 Phillip's, iirc) and used those screws to put a non nav dash pocket/cubby in. It fit the brackets with no additional work and lined up like OEM. Also gutted the dvd from upper glove box and put the storage insert in from a non nav coupe. Not much real estate gained, but I cut a small hole and used a rubber grommet to pass through my amp's control panel on a hinge, so I can keep my wheel lock and a flashlight behind it in the little storage spot.
