Aftermarket steering wheel; air bag bypass?
Old Feb 26, 2020 | 12:12 PM
Terence Wong's Avatar
2005 Infiniti G35 Sedan RWD automatic
Just installed a nrg quick release and steering wheel on my 05 G35 coupe but even after I put in the air bag resistors that came with the kit, the air bag light still flashes? Yes I did the air bag reset that the other forums posted but it still flashes. Anyone know why?
Is there any way to troubleshoot the light to pinpoint the exact problem?
Old Feb 27, 2020 | 10:17 AM
Urbanengineer's Avatar
There's a way to check the codes buried in the forums here.
Likely wrong sized resistors.
Old Feb 27, 2020 | 11:02 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Old Feb 27, 2020 | 11:39 AM
Dang you are too kind.
Old Feb 27, 2020 | 03:39 PM
do you know the correct resistor size? I figured the right one should have came with the parts.
Old Feb 27, 2020 | 07:57 PM
cleric670's Avatar
BANNED!!!
Turns out you need TWO of the 2 ohm resistors, there must be 4 total wires or something, I didn't take mine apart just reading about it on the 350Z forums.
Old Feb 27, 2020 | 10:56 PM
you mean 4 of these all together? cause I have these 2 hooked up to each plug of the air bag. Maybe I’ll try adding 2 more. If it works I’m guessing it just needs higher ohm resistors
Old Feb 28, 2020 | 11:48 AM
cleric670's Avatar
BANNED!!!
First thing I'd do is take a digital multimeter, set it on resistance/ohms (if you have multiple ohm settings pick the one that's a low range like 20, not 200 or 20k) and measure to see what those resistors are. You want the total resistance to be 2.2 ohms according to everything I saw yesterday.
Here's the main thread I was looking in on my350Z
https://my350z.com/forum/body-interi...all-diy-3.html
Old Apr 26, 2021 | 07:59 PM
bossmanblaine's Avatar
G35 Coupe
hey bro, did you figure out how to turn the airbag light off? would love to know!
Old Apr 26, 2021 | 08:28 PM
cleric670's Avatar
BANNED!!!
Fix the problem that's turning the light on, then the light turns off. You can put the system in diagnostic mode to find out why the light is on.
andrewvk
Interior
May 28, 2015 07:05 PM
R1ricer
Archived Sales
20
May 3, 2010 09:38 PM
BAD430BENZ
Archived Sales
Jul 23, 2008 04:59 PM
luxbond
Archived Sales
Nov 26, 2006 06:47 AM
