Engine swap
Old May 9, 2020 | 12:58 PM
Jaydon Faucett's Avatar
g35x
Unhappy Engine swap
I have a 2008 G35x after the car getting totaled I was looking into swapping the motor into a 2008 G35. I was wondering what issues i
may run into while doing so because the G35x is awd and I'm not sure if there is a difference in the wiring. Anything helps.
Old May 24, 2020 | 01:56 PM
Ethan K.'s Avatar
Red 6MT (Rev-Up) Coupe
Hmm I’d think that as long as everything is correctly installed and in place, you’d be fine. Only difference is that you won’t have a transfer case in this one, if you’re using the ECU from your previous then yeah make sure you won’t have to do any tunes. Other than that, it should be a simple swap, again, if everything is correctly put in place. Good luck!
Jaydon Faucett
May 9, 2020 03:56 AM
Jaydon Faucett
V36 Engine, Exhaust, Drivetrain & FI
May 3, 2020 11:25 PM
kgame@78
Jul 26, 2018 03:17 PM
mdaws69
Dec 10, 2017 11:36 AM
mikebatch
Oct 7, 2011 11:02 PM
