Engine swap
Old May 3, 2020 | 04:40 PM
Jaydon Faucett's Avatar
g35x
Engine swap
So i have a 08 g35x and that was involved in a wreck and is more expensive to fix then the car is worth. I was considering putting the engine in a different G and was wondering how difficult it would be to swap a hr into a de engine bay. Main issue is making sure the engine mounting points are the same.
Old May 3, 2020 | 11:07 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Engine, transmission, wiring harness, ECM if you're going to swap to a different platform engine, plus a myriad of other smaller things like routing AC lines and such.
There's plenty of folks that have done an HR swap on either the G35 or 350Z so you should be able to google up a wealth of knowledge.
If you want EASY then you should shop around for another HR platform car that has a blown up engine or transmission.
Old May 3, 2020 | 11:25 PM
g35x
thanks for the help
will do a diy if i decide to do it
Kyle Seward
Apr 18, 2019 05:38 PM
azatabbasov
Nov 12, 2016 09:13 AM
andrewx373
Nov 13, 2014 12:16 AM
?shortshift.
Mar 26, 2010 06:28 PM
FI'ed G
Dec 19, 2005 03:02 PM
