06 g35x
Old May 17, 2020 | 12:47 PM
Michael Benton's Avatar
Awd
06 g35x
Hey my 06 g35x wouldn't go over 2200 rpm i replaced the maf the ecu the throttle body and the dealership reprogram the ecu and it still wouldn't go over 2200rpm then two weeks later i go in the yard to check on the i started it up and it was running good i drove it and it went over 6000 rpm so now its good what could cause it ?? But vdc slip and engine light is still on
Old May 17, 2020 | 03:04 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
If the check engine light is on then the computer is trying to tell you what the problem is. Plug in an OBD2 scanner and see what codes it is throwing. Anytime you disconnect the throttle body you need to perform the throttle closed recalibration steps as shown in the factory service manual. Section engine controls, under general service procedure at the start of the manual.
Old May 17, 2020 | 05:01 PM
Awd
i hooked up a code reader and code came up pcm/ecm connector my not be hook up gud do tht sound bout rite??
Old May 25, 2020 | 03:59 PM
Ethan K.'s Avatar
Red 6MT (Rev-Up) Coupe
That sounds like your crank/camshaft position sensor has gone bad. It’ll need replaced.
Old May 25, 2020 | 06:04 PM
cleric670's Avatar
BANNED!!!
Which error code exactly.
dpark0223
Dec 1, 2015 01:14 PM
Cajuncowboy
Aug 19, 2015 11:53 AM
itsmrg35
Nov 16, 2011 09:33 PM
