Passenger window
Old Oct 25, 2020 | 09:16 AM
owen'sg35's Avatar
base coupe 2 door 3.5L 3498cc V6 with a few small mods
Passenger window
Hey all, I've got a small problem and was hoping somebody could help me with it. So a few weeks ago my passenger side window stopped working and naturally I assumed It was the motor.
Jump ahead two weeks, I installed my new motor and..................... nothing. Any help on this would be appreciated. Thanks.
Old Oct 25, 2020 | 11:29 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Unplug the motor and use a digital multimeter across the pins 5/6 (I think the orange and purple) in the harness. It should be like +5vdc with the window switch in the up position and -5vdc with the switch in the down position. If you're not getting power to the motor then start backtracing the wiring.
It's not uncommon for the wiring to break in the flexible conduit section where the door attaches to the chassis. If you have power at the window switch but it's not making it to the motor then that's probably the issue.
EDIT: Here's a link to the FSM, check section GW - Glass/Windows for the wiring schematic.
https://www.nicoclub.com/infiniti-service-manuals
Old Oct 25, 2020 | 02:43 PM
owen'sg35's Avatar
Thanks cleric, I'll check that out.
marcoxv
Feb 13, 2023 07:23 AM
Z 2 G
Jan 24, 2012 08:37 PM
mprat1985
Archived Sales
Dec 25, 2009 08:44 AM
shdowflare
Interior
Jun 18, 2009 09:50 PM
