2008 G35x not blowing air, new member please help
Old Oct 31, 2020 | 03:02 AM
AWDchris's Avatar
G35x black on black leather
So I recently purchased a 2008 G35x sedan and I figured id ask for some input. It has one small issue. When my fan is at any speed it's not blowing air at all. So my question is that is there a relay I should check first or the blower motor? It's not leaking coolant or anything by the way. Figured I'd mention. Any help is much appreciated.
Old Oct 31, 2020 | 03:11 PM
telcoman's Avatar
Veteran: Army
Your post is not very clear.
You have separate left and right temperature settings.
Are both sides not working?
Is your blower motor not working at all?
Follow the troubleshooting steps in the FSM
https://www.nicoclub.com/service-man...n/2008/HAC.pdf
See page HAC 66 and HAC 81
Good luck
Old Oct 31, 2020 | 03:14 PM
AWDchris's Avatar
Good luck
It's not blowing air at all. Both sides aren't working. Thanks for the info I'll look into that. I gotta test this blower motor it seems.
Old Oct 31, 2020 | 03:18 PM
telcoman's Avatar
Veteran: Army
It's not blowing air at all. Both sides aren't working. Pretty clear on my description.
Then use your multi-meter and test for voltage at the blower motor
Old Oct 31, 2020 | 05:24 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
It's almost always the blower relay, Fuse Block - J/B which is located in the left footwell kick panel. First disconnect the battery, next remove the entire kick panel (usually the door trim with the INFINITI badge, then the fake foot rest, then the kick panel), then remove the two 10mm nuts holding the fuse block down. Lift it up and you will see some blue colored relays, you can swap any of them with the blower relay to test. I strongly recommend using a sharpie marker to label which one was the blower relay so you don't get the bad one mixed up with the rest.
Ideally you would swap with the rear window defroster relay so you aren't disabling your starter or accessories.
Autozone carries the OEM Nissan relay for some reason. They're like $25.
Here is the schematic for the back side of Fuse Block - J/B.
Old Nov 11, 2020 | 12:42 PM
AWDchris's Avatar
Thank you! Just replaced the blower motor and still nothing I have a feeling it's just the relay, thanks again for the diagram super helpful!
Old Jun 15, 2023 | 04:58 PM
lazz0645's Avatar
2008 g35s
I know this is an old thread, I’m having the same issue, did you ever figure out what it was? I swapped the rear window relay and the blower relay to test and it still didn’t work, replaced the blower and the fuses. TIA.
midnytegsedan
May 23, 2017 01:45 AM
justgotg35
Jul 19, 2015 12:33 PM
Geomar Morales
Aug 16, 2014 04:19 AM
dswtflip4u
Jan 14, 2012 05:25 AM
ksiskin
Sep 2, 2011 12:40 PM
