No Automatic Rev Matching
Old Nov 30, 2020 | 04:33 PM
David Lara's Avatar
2003 Infiniti G35
Hello, I have an 03 G35 and it is an automatic. I’ve heard that 03’s and 04’s do not have automatic rev matching. I tried it for myself and can confirm that it has no automatic rev matching, it just dumps the clutch. Is there any way I can somehow manually rev match or bypass the clutch from dumping itself?
Old Nov 30, 2020 | 04:47 PM
andrewl_v35's Avatar
04.5 G35 Sedan 5AT
I've been able to 'blip' the throttle slightly when downshifting my '04.
I have the Works Bell column shift kit on my G, and since I've installed it I've learned to tap the downshift paddle and then lightly tap the accelerator.
Downshifting to 2nd gear seems to be rough almost no matter what, so I just shift to 2nd when the revs are below 1500 rpm.
Old Dec 4, 2020 | 06:24 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
You would need to handle engine rpm with the gas pedal, the 2005+ rev matching engine control is handled through the ECM. Just blip the gas when you're downshifting.
However it's not going to hurt an auto tranny, it's not "dumping a clutch" because there's a torque converter in the middle designed specifically to handle these shaft speed differences.
specialist
Jan 17, 2011 07:31 PM
LoveLife-
Jul 15, 2008 10:09 AM
mc2
Sep 13, 2005 12:55 AM
Atooraya
Aug 30, 2005 05:21 AM
weiweiwei
May 20, 2005 08:35 PM
