Problems with Lights
Old Jul 19, 2021 | 12:08 AM
AwayV2's Avatar
G35 Coupe
reverse light used to work now they don't, swapped them out with all new bulbs and only the driver side shortly comes on then off if i bang the taillight assembly hard enough, also the passenger fog light won't come on but the amber lights turn on when i use the turn signal and the passenger side marker light won't come on, any ideas how to fix them? is it the fuses because i checked the harness wiring for taillights and everything seems to be in normal working order
Old Jul 23, 2021 | 02:01 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
If it's a sedan a common problem is for the wires to break inside the flexible wire loom for the trunk. Disconnect the battery and take the loom apart to see if the wires are broken, usually people pull new wires through the loom and solder/shrink them on both sides. Eventually they will break and arc out against one another and blow fuses.
Old Jul 23, 2021 | 09:06 PM
AwayV2's Avatar
G35 Coupe
does the coupe have the same issue? i inspected the wire harness and it looks in pretty good shape should i just proceed to tear it apart and see what's up? or do i check all the fuses first? which fuses do i replace and where can i get them?
Old Jul 23, 2021 | 09:34 PM
cleric670's Avatar
BANNED!!!
Well since percussive maintenance (banging on it) is doing something it's probably a loose connection somewhere at the tail light assembly. Take it apart and spray a plastic safe electrical contact cleaner into the plug where the lamp goes. Make sure to let it dry before reinstalling the lamp.
Also check the harness for any corrosion and clean it up with contact cleaner as well.
MAKE SURE THE CAN SAYS SAFE FOR USE ON PLASTIC!
Old Jul 28, 2021 | 05:48 AM
AwayV2's Avatar
G35 Coupe
thanks for the reply sorry for the late reply have been busy and currently away from my G gonna follow your tips first thing when i get back home and post the results, thanks again
LaserRedG35VS
Nov 16, 2010 06:13 AM
The-Dream
Lighting
21
May 8, 2009 05:43 PM
jutn35
Lighting
May 2, 2008 01:20 AM
gtowner
Lighting
Apr 24, 2008 05:21 AM
_G_
Oct 13, 2005 10:52 PM
