G35 Cranks but does not RUN
Old Nov 6, 2023 | 03:28 AM
raijin04's Avatar
Red G35
Hello so during my research, I have come across so many people saying that the solution to fixing the crank no start problem by changing the cam (passenger, driver) sensors as well as the crankshaft sensor. So today, I have changed all three using the Hitachi brand; and it still did the same thing. I have tried resetting the ECU, and the other additional relearning steps like for the throttle body. I even bought a new battery to test and even put a gallon of gas into the car. Last year, I changed the fuel pump, throttle body, and MAF as they are brand new technically. I have checked the fuses by the battery and did not see any of the fuses blown.
The G35 was running before and just stopped starting again. The main issue before was that when I cranked it, it would start and immediately shut down. I drive an automatic sadly.
Any suggestions?
Old Nov 10, 2023 | 11:08 AM
LDSauce's Avatar
Stock G35
And the battery is putting out the correct voltage right? You can buy bad new batteries
Old Nov 19, 2023 | 05:00 PM
raijin04's Avatar
Red G35
yeah I checked the voltage and it said 12.4V. I might try use electrical cleaner for my sensor terminals but there’s really nothing else I could do
Old Nov 20, 2023 | 07:19 AM
Scorpi0's Avatar
U sure your fuel pump works? Try spraying some starter fluid into the intake as you crank the engine. See if it tries to start like that.
Old Dec 17, 2023 | 07:28 PM
raijin04's Avatar
Red G35
Yeah it did start. After I did it though I seen some white smoke coming out of my engine.
Old Dec 17, 2023 | 07:29 PM
raijin04's Avatar
Red G35
Exhaust* not engine
Old Dec 18, 2023 | 10:26 AM
LDSauce's Avatar
Stock G35
when I had this issue it was because the relay on the IPDM went out that controls the Fuel pump.
Dani01c
Dec 2, 2024 08:44 AM
Miss.Bosslady
Jun 24, 2022 11:36 AM
thomasmarzec
Jan 26, 2017 08:36 PM
Risktaker
Oct 1, 2012 12:34 PM
cloud
Dec 8, 2006 05:14 PM
