Grey smoke!!
Old Feb 3, 2025 | 02:17 AM
waokasha's Avatar
g35 automatic
Grey smoke!!
Hello people, so i noticed my 2004 g35 has been emitting grey smoke from time to time and I'm looking for the possible causes. I've tracked the situation and here's what i found.
Situations when it smokes:
- After going uphill, when going downhill: constant smoke
- After idling when I gas it a little a cloud comes out, but after that nothing at all.
About my car:
- It has a single exit exhaust with the catalytic converters present but no stuffing.
- I've noticed no coolant level decrease at all, and no oil level decrease at all.
- Car drives like a charm and I don't beat it that often.
- Changed the valve covers not long ago cuz they were leaking oil, nothing else.
You can see an example here:
Old Mar 29, 2025 | 02:00 PM
G35Cincy's Avatar
Infiniti
If you have time check for more oil leaks at some point in combustion cycle you are cooking off fluid from a leak. Gauge for coolant temp wouldn’t really be an immediate indicator. Only because you can loose a lot in small quantities gradually and get white smoke for burning oil and/or coolant.
escozoo
Sep 21, 2024 07:11 PM
good gravy
Aug 25, 2020 10:55 PM
fitgineer_93
Jun 15, 2019 02:46 AM
Thoeun Se
Nov 5, 2017 03:13 PM
alistaircookie
Nov 20, 2014 03:54 PM
