Electrical bug
Old Oct 7, 2005 | 02:16 PM
clifftrail's Avatar
Electrical bug
Sorry this has to be my first post, but I've got an problem with the lights and hopefully someone has a tip.
2003 G35 Coupe.
Anyway, what I was doing was using my ohmmeter looking for a switched power source in the back of the car. I disconnected the electrical connector running to the drivers side tail light, had 5 wires, pretty thin, didn't figure one would work but I tried it anyway. I was using the probe to see if one of the wires was a switched source and I figure I touched two contacts together with the end of the probe as they are very small and it's pretty easy to do. Anyone remember "Operation".
Put it all back together and now I don't have parking lights or courtesy lights on the climate controls or radio, but everything else works fine.
I figure I blew a fuse or need to reset a relay somewhere but I've looked at the fuse box near the battery and the one on the drivers side kick panel and can't find any blown. Does anyone have any idea where the fuse/relay for the parking lights is at? I figure it's one circuit that I shorted out. Thanks if you can help.
Old Dec 13, 2005 | 09:19 AM
playboy13's Avatar
having same problem...sorta..
I just got my G back from the shop...after a month rear end collision ( with a tree ) dont ask... I know they replaced my driver side taillight along with a bunch of other stuff..and now my gauge cluster wont light up, my ac/radion controlls dont work...have you had any luck figuring out why it happenned?
Old Dec 13, 2005 | 10:48 AM
g35rcr's Avatar
did you check the fuses in the engine bay yet...also try unplugging the battery over night with the windows down a crack or doors open so you dont damage the glass
Old Dec 13, 2005 | 11:26 AM
Maximus's Avatar
Sounds like u jus shorted something and blew a fuse...no biggie...there should be spares in the fuse compartment, wherever that is
Old Dec 13, 2005 | 11:37 AM
Hotrod's Avatar
I would carefully check the fuses I would bet money you just blew one of them.
Old May 5, 2009 | 09:15 PM
acemallone's Avatar
I have the same problem, no blown fuse!!! I need help!!!
Freeman186
Sep 6, 2023 10:07 AM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
NyCrAzY
Oct 1, 2015 09:19 AM
vamarris
Sep 26, 2015 12:56 PM
