Hey guys,
I have KAIXEN HID Kits available for G35DRIVER members at a great price. These kits have one of the lowest defect rates in the industry.
Here goes the basics:
What is HID?
HID (high intensity discharge) : The light is emitted from an arc discharge between two closely spaced electrodes hermetically sealed inside a small quartz glass tubular envelope capsule. To operate, they require ballasts, which supply proper voltage and control current. The amount of light produced is greater than a standard halogen bulb, while consuming less power, and more closely approximating the color temperature of natural daylight.
3 X brighter than any Halogen bulbs. Typical halogen bulbs will give you anywhere between 500 to 1000 Lumens, while consuming 55 watts or more. HID on the other hand will give you 3200 Lumens (based on 4300K) which is more than 3 times the light output of halogens.
The difference in light output is like day and night.
Whiter light: The color temperature of HID lighting more closely approximates the color temperature of natural daylight than does a halogen system, which appears yellowish in comparison.
You also have the option of getting Pure White (5000K), Crystal white (White with blue in certain angles), Cyrstal purple (6500K), and Crystal blue. (8500K)
Consume less power. Only 35 watts of power is used.
Lasts almost 10 times longer than halogens. HID bulbs will last about 2500 hours. This means, it will last about 3 to 5 years of regular usage.
In case some of you are not aware of the KAIXEN brand, here are a few key facts:
KEY FACTS:
1. These are 100% genuine Made in Korea brand.
2. Kaixen HID kits were first sold using Philips / Matshu****a ballasts and bulbs starting in 1999. Since then, Kaixen has recieved its own license as well as hiring several key engineers from Germany to develop its own high quality ballast / bulbs since 2002.
3. Only company other than Philips to develop the diamond-cut bulbs.
4. Kaixen is ISO2001 registered, E13 certified, KQA quality assurance certified.
5. All Kits are made direct from the factory, and are not "re-based" as most Philips HID kits are made.
6. Fit and finish quality is second to none.
7. Quality comparable to if not better than OEM material.
8. Comes with 1-year full replacement warranty.
Competitive comparision:
1. Made in China / Taiwan products: Yes, it's cheap. But not by large margins. Although "Made in China" products have improved in recent years, most of the HID manufacturers in China are poorly managed, uses cheap labor (more risk of defects), uses cheaper raw materials (risk of defects), and fit and finish is poor compared to other Korean / Japanese / German brands. There's a reason why many of these kits (mostly sold on EBAY) are sold for around $200 or $250. It's because it costs that much less to build, many times, cutting corners in areas that shouldn't be cut.
2. OEM / Philips: Direct OEM replacements cost around $600 per one side (over $1000 for both sets). Therefore, many people go to the "next bext thing" = Philips. However, what most people dont know is that Philips do not make variety of sizes. Philip's buyers (like Audi do not use all variations of sizes). This is why many resellers "rebase" the Philips bulbs to make it fit into sizes that are not originally made from Philips factory. There is a risk of product defect because of this modification. This is also another reason that many Philips kit's warranty is only valid from the reseller, and not from Philips head office.
As a comparision, Kaixen manufactures all sizes and colors directly from their manufacturing facility in South Korea. There is no rebasing or modification done outside of the factory, and all warranties are offered directly from Kaixen.
Here are some pictures of other cars with KAIXEN HID Kits:
More pictures found on www.kaixenkits.com
Colors available:
5000K (Crystal Natural),
6000K (Crystal White),
6500K (Crystal Purple),
8500K (Crystal Blue).
Less Kelvins (K) has better Lumens (Brightness).
More Kelvins (K) has more Colors.
And yes, these are "plug and play" kits with easy installation.
PRICE:
$279 USD single beam kit shipped anywhere in the U.S., $299 USD single beam kit shipped to Canada. Email me for a price on the dual beam kits.
Feel free to email me (sales@autodoodad.com) or PM me for details.
To order a kit: Send me your email address to Sales@autoDoodad.com so I can send an email invoice to you for a secure credit card payment.
What is HID?
KEY FACTS:
Colors available:
PRICE:
Quote:
Yes, We carry the 3200K HID's, they are usually used for fog lights.Originally Posted by spddmn124
you have any 3000k HIDs??
i have a question ? im pretty much new to the car thing, but i have a 2003 g35 coupe. and i know it has HID already. but i want a second set. but i want to to be the same color as my stock. so it can go at the buttom. can someone help me out ?
I have a Canadian-spec '06 G35 Sedan with halogen high-beam/DRLs. Do you sell a kit that will convert the high-beams and also work as HID DRLs? I believe the power (wattage) to the socket is halved during DRL operation, and I would suspect that would cause problems for any DRL conversion.
I bought the mccullogh bi-xenon H4 HID set and they suck!!! the low beam (fog light) is great, but the high beam is almost non-existant. I think you really need a bi-xenon H4 that moves the burner in and out to properly focus the light....the mccullogh set has a shield that moves, and it is not effective on the high beam portion..
I would be interested in just a bi-xenon H4 set of bulbs.....do you have any actual pics of a G35 sedan with these in? light output pics, etc?
Do you carry the Philips 6K bulbs. I don't need the kit, just a pair of D2S bulbs.
Thx....
Thx....
pm me for what i need to replace projector bulbs in 06 6mt? i like the crstal white w/ blue
