Hawaii Honolulu
Question about tire and wheel spacer stuff.
Old Aug 9, 2006 | 05:22 AM
aleok's Avatar
i'm getting the M45 rims, for my coupe, which have a 50 mm offset. i will need some pretty huge wheel spacers, just for them to fit. i'm currently lowered on 350z s-techs, and plan on lowering a LOT more with coilovers, like 2 more inches. i'm using the oem 19" tires, 225/40/19 and 245/40/19.
the question is:
whats the largest wheel spacer i can get, but when i'm lowered not have the tire hit my fenders. (assuming the camber is in OEM specs). fenders rolled and not rolled...
thanks.
Old Aug 9, 2006 | 05:59 AM
636Racer's Avatar
Kics project 30mm should do the trick.
Old Aug 9, 2006 | 06:21 AM
aleok's Avatar
i won't rub when i'm slammed so much?
are these ok to get? i mean the brand (or lack of brand) damn i didn't know spacers where to expensive.
http://cgi.ebay.com/ebaymotors/5x114...spagenameZWDVW
Old Aug 9, 2006 | 08:11 AM
lowrider's Avatar
Talk to this fella:
https://g35driver.com/forums/picture-share/111268-some-new-pics-my-car-enjoy.html
Lou
Old Aug 9, 2006 | 09:18 AM
aleok's Avatar
i have been, but hes only lowered on tein h-techs, and doesn't know if he can drop any more without rubbing...
Old Aug 9, 2006 | 02:41 PM
sen_jen's Avatar
Meatshake Enterprise
just don't run fatty swamper tires. run a 30 series in the rear. depending on the brand, it won't be too drastic over oem.
also, remember that adding a wider stance is good, but if you hit crazy potholes/bumps you add stress on the suspension components. this leads to bending of them.
Old Aug 10, 2006 | 12:31 AM
aleok's Avatar
i'm going to be running the oem 19"s because i can't afford to be buying new tires now. so that the 40 series. so will a rim with 25mm offsets (if i get 25mm spacers) rub on a G thats dropped like 2 or more inches? i picked up the rims today, so i need to order my spacers asap!
Old Aug 10, 2006 | 12:39 AM
sen_jen's Avatar
dropped 2+ inches, yes you may rub. 40 series is crazy with a drop like this.
Old Aug 10, 2006 | 03:01 AM
636Racer's Avatar
keep in mind if you go with buddyclub or stance coilovers. Too shallow an offset in the rear, you'll end up rubbing the coilover. you'll be safer with 30mm spacer.
Old Aug 10, 2006 | 04:24 AM
nouse4aname's Avatar
dont rush to put em on just cause you have em. maybe you should listen to senjen and maybe buy smaller rubber first. if you start rubbin and s..hit, you may cause some expensive damage.
Old Aug 10, 2006 | 04:46 AM
636Racer's Avatar
I have 2 - 5mm spacers, double'm up and get 10mm. If you can find anyone with 15mm and 20mm spacers...see if you can borrow them to test fit...then you'll know what size spacers you need to buy.
Old Aug 10, 2006 | 07:22 AM
aleok's Avatar
well i know i shouldn't rush. but as of now, i'm not dropped, super low, so i don't THINK i would rub now. and as for when i do get the coilovers, i just won't drop it so low untell my tires go, and then get some 30's and slam em.
*** the 30mm spacers are 20 buck more, 40 fricken dollars for 5 more mil. idk if i can "test" fit of any kind, because i'd need to swap the tires off the rims i have now, which i can't do untell i'm really for install.
Old Aug 10, 2006 | 07:29 AM
aleok's Avatar
damn will the 225 tires even fit on 8.5in rims? can yea?
ma_sha1's Avatar
You could get 25mm spacer & stack on another either 2mm or 5mm depends on your test fit.
I am running a Kitc 20mm spacer + a 2mm spacer, I don't want
the wheel to be pushed out too much because my BBK.
I had to get 225 tyre to replace my 235,
BTW my 235/45 18 Tyre is up on ebay incase anyone want a set:
http://my.ebay.com/ws/eBayISAPI.dll?...=MyEbaySummary
Old Aug 10, 2006 | 08:38 AM
aleok's Avatar
^ true, just if i get the 25mm that make the total wheels offset 25mm. so the coupes that are slammed have what kind of wheel offsets?
