Hawaii Honolulu
offset
Old Feb 4, 2007 | 06:29 AM
gwasabi's Avatar
offset
If i were to get 20 inch amistad c rims, what offset would I need to get so that I wouldn't have to pull the fenders? I want the most aggresive look without pulling the fenders
I was thinking 25 in front and 20 in rear.
Old Feb 4, 2007 | 07:30 AM
DTR_Projekt's Avatar
hard to say. Depends on what width you go with, how much camber, and how low you like go.
I have a 20x10.5 +25 on my rear. Get choke space. I ran a 3mm spacer on it easy, fenders not even rolled. I believe G35maniacG35 has the same rear as me, and is runner a larger spacer.
Front I have a 20x8.5 +25, and I ran a 8mm spacer at the august show.
You might want to roll your fenders if you on coilovers. Beangrowers fenders are rolled, and had choke room when he used to run his 20's. I don't think I know anyone with a G that had to pull fenders.
Talk to REV-01. He is a guru at calculating offsets, disks, widths, etc.
Old Feb 4, 2007 | 03:10 PM
G35maniacG35's Avatar
I am running 20X10.5 +25 in the rear and I also have a 8mm spacer, in the front running 20X9.5 +25 and im sitting on Tein S-techs and I still have plenty of room just make sure you stretch your tires. Like DTR said talk to ReV he is the master at sizes and you also have Sen_jen who knows alot about wheels.
Old Feb 5, 2007 | 01:30 AM
gwasabi's Avatar
I was gonna run 20 by 10.
Maybe i should go with +20 offset then and +25 in the front.
I plan on going coilover but only to get rid of that ugly fender gap.
Als oplan for maybe a -2 camber in front and -1.5 in rear
seagrasser
May 3, 2022 09:43 AM
Picture Share
Feb 4, 2018 12:41 PM
alxmlr789
20 Inch
Jan 26, 2016 10:04 AM
TurTLe*
Sep 29, 2015 01:43 PM
