Hawaii Honolulu
G35 Power locks fail!
Old Jan 13, 2009 | 05:12 AM
Daddylongstroke's Avatar
Hey guys, my pasenger side power lock failed a month back. It doesn't lock/unlock using the key fob anymore. I got a quote from Infiniti for $450 to get it fixed. I just saved up some cash to get it done, and now the driver side failed! Damn, I can't see paying almost a grand for door locks! Anyone know a cheaper way to get these fixed? Would putting an aftermarket alarm system replace the stock door-lock mechanisms? Any help would be greatly appreciated. Thanks in advance guys.
Old Jan 13, 2009 | 03:27 PM
Ready2Play's Avatar
No, it won't. Aftermarket alarms run off of the stock actuators. Let me know if you find a good deal to fix this....my driver side is slowly going out..
Old Jan 13, 2009 | 07:41 PM
M-azing.'s Avatar
i have the same problem dont worry man i feel your pain
Meatshackle's Avatar
Deep Sea Moderator
Do a search in the tech section. There have been members getting new actuators for under $200. $tealership is waaayyyyy overpriced.
Old Jan 13, 2009 | 08:58 PM
GZire's Avatar
What year is your G?
Old Jan 14, 2009 | 12:06 AM
its a 2003 coupe. Did a search and only thing I found cheaper is an aftermarket actuator DIY install but it involves some fabrication of sheet metal and drilling. I'm not sure if that method is reliable...I'll keep u guys posted if i find any deals. shoots
Old Jan 14, 2009 | 08:45 PM
myroncuz's Avatar
a guy made a thread on a cheaper door actuator.. dont do it.. he said it failed later on.. my driver side had the same problem at times but now for some reason works fine after my alarm was installed.. but, they do use the same actuator like ready2play has said.. i would just buy an oem one from riverside on ebay or elsewhere and install that on your own. check out the tech or diy section..
Old Jan 14, 2009 | 08:46 PM
myroncuz's Avatar
oops, i also heard someone say that they bought a 350z actuator and it worked just fine.. its supposed to be 30 bucks cheaper
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
will091195
Jul 27, 2015 09:19 PM
laksjd84
Jul 24, 2015 05:12 PM
apintojr
Jul 23, 2015 10:52 AM
