Hawaii Honolulu
Car at IDLE...
Old Jan 26, 2005 | 01:46 PM
jdbinspired's Avatar
Car at IDLE...
What is everyone's rpm at idle...?
Old Jan 26, 2005 | 01:51 PM
XLR8SN's Avatar
800 RPM. Whats up with yours?
Old Jan 26, 2005 | 01:59 PM
800rpm.. Wow... that's pretty high... Ever since I bought my G... it's been at around 200 to 400 only... I thought That was pretty low but never really bothered getting it checked... Hmmm... That sucks...
Old Jan 26, 2005 | 02:45 PM
sen_jen's Avatar
Meatshake Enterprise
same as you bah.
Old Jan 26, 2005 | 03:21 PM
oh okay.. I feel a little better now... I was jsut worried if I tried to bring it into the dealer they would tell me it was because of the plenum when i know it was idling like that before I even installed that thing... oh well okay... nothing to worry about... good deals...
Old Jan 26, 2005 | 05:57 PM
g35john's Avatar
200 to 400 is a bit low. Mine stays around 500 to 600. Its a 6mt also.
Old Jan 26, 2005 | 06:07 PM
Does anyone know how to advance the timing or up the fuel pressure or will that way only work with honda's...?
Old Jan 26, 2005 | 07:20 PM
geeezus's Avatar
mine idles about 5 or 600.
Old Jan 26, 2005 | 07:22 PM
XLR8SN's Avatar
You will need a consult II to advance the timing....and even at that..maybe only 2 degress. But you do know that after a while, the ECU might retard the timing anyway. The stock fuel pressure I believe is not adjustable. Thus it becomes dependent on the ECU to calculate how much fuel is needed.
If your engine is idling really low...wouldnt that mean that you are running too rich? Maybe the ECU is dropping the timing to avoid pingging. Either that or bad gas = too low of an octane level. Try to change gas stations. Use like a 76 or Chevron station for a little while. Sorry but Aloha gas does not cut it.
Therefore......if all else fails. Take it to Infiniti. That idle speed just sounds way too low.
Hey,....that might be the reason on the slow track times. Timing is really bad.........pun intended.
Anyhow, get it tended too. I dont think that it is at all normal for that low of an idle.
Old Jan 26, 2005 | 07:27 PM
sen_jen's Avatar
^ big aloha to you mah bruddah. the 411 is geez.
Old Jan 26, 2005 | 08:42 PM
DHCrocks's Avatar
eh Jeremy, sorry I didn't get back to you sooner, was so busy during the holidays. still got that CEL light on? The stock tachs are usually not that accurate so it may not be reading right, I'll be home around 3pm on Friday. If you're around give me a call and we can hookup the OBD2 scan tool to check your actual RPM and reset your CEL and see if there are any other trouble codes.
Old Jan 26, 2005 | 09:03 PM
sen_jen's Avatar
^ you think you can scan mine too? i live by jeremy. lmk. TIA.
Old Jan 26, 2005 | 09:26 PM
636Racer's Avatar
Is there a compliant onboard scanner for the G35? I used to run a Laptop and a realtime scanner software in my buick. People used to think I was a cop and slowed down everytime they'd see the laptop open. (I had the holder and all) I used it whenever I'd make a few shakedown passes at the track to monitor knock retard, fuel pressure, boost, rpm, vehicle speeds and all that good stuff.
Old Jan 26, 2005 | 09:27 PM
Msedanman's Avatar
O.F. Administrator
Mine with the stock intake idles at 650. With crawford and cai, it idled about 700 to 750.
Old Jan 26, 2005 | 10:33 PM
Asao's Avatar
Since day 1 between 500-600. No mods.
