Hawaii Honolulu
Broken rear strut stud!
Old Dec 14, 2005 | 07:36 PM
808HerbzG35's Avatar
Unhappy Broken rear strut stud!
It's over a month since my new arm links; I was checking and retighten the rear suspension and over tighten a worn 12mm. Here's a pic "with was" going be new 13mms.
Behind the rear seat, were I access my dampers:
I guess I have drive like grandma for a while.
Old Dec 14, 2005 | 07:41 PM
sen_jen's Avatar
Meatshake Enterprise
i highly recommend you not drive until you get this fixed. seriously. also, i don't think you over tightened. i think you threaded it on incorrectly, and stipped it.
Old Dec 14, 2005 | 07:56 PM
BACES's Avatar
stripped the bolt!! ahhhhhhhhh!!!!
Old Dec 14, 2005 | 07:58 PM
BACES's Avatar
once i incorrectly threaded a spark plug and i stripped the heads of my 71 VW...hahaha!!!! fricken thing blew out of the motor and busted through the engine hood.. ON THE FREEWAY!
Old Dec 14, 2005 | 10:04 PM
GZire's Avatar
Was it a graded bolt?
Old Dec 14, 2005 | 10:35 PM
hehe it's a real herbie bug.
Since the bolt's head is really welded with the chassis. I think I’m going drive around look for some kind of bolt kits, dremel off the shortened stud, & drill through for the new bolt. Any better ideas/hints/tips??? Thanks
Old Dec 15, 2005 | 12:36 AM
636Racer's Avatar
Go to Hawaii Nuts and Bolts in Mapunapuna, by the old Mid Pac lumber yard...ask for Ben Kahanu. Tell him you know Chris Billete, he's an old baseball team mate of mines from highschool. I hope he still works there.
Old Dec 15, 2005 | 12:18 PM
jdbinspired's Avatar
mang... that's not good... wut duh... JB WELD em...
Old Dec 15, 2005 | 05:14 PM
GZire's Avatar
You can also try Industrial Hardware Hawaii, but Hawaii Nut & Bolt is definitely preferable.
You need to make sure you match the grade on the bolt/stud correctly. You don't want a mounting point to go before the bolt, if the car is designed so that the bolt goes first.
Old Dec 16, 2005 | 05:55 PM
JB what what???
Old Dec 16, 2005 | 07:28 PM
GZire's Avatar
JB weld is a bad idea.
Old Dec 16, 2005 | 07:44 PM
Whoa, dirty JD! You like make me break my car aye! Haha, "breakInspired."
Old Dec 21, 2005 | 08:04 PM
Thumbs up
Yo, the "dremel off the shortened stud, & drill through for the new bolt" plan worked...
Big mahalo to skylar's help on this.
Old Dec 21, 2005 | 09:57 PM
636Racer's Avatar
good fix, where did you end up buying the nut and bolt?
Old Dec 21, 2005 | 10:52 PM
^Thanks. Lowe's; so far selections for automotive nuts/bolts are okay. Since this was not done in a shop, we use the rear a-arm and diamond floor jack to give the hammerdrill an extra push from the ground.
