Hawaii Honolulu
Guys Please Help Me!!!
Old May 1, 2006 | 10:32 PM
DHCrocks's Avatar
hold on, I have the relay wiring color chart at home, I'll look it up tonight.
Old May 1, 2006 | 11:25 PM
aleok's Avatar
doomo
Old May 6, 2006 | 05:02 AM
DHCrocks's Avatar
sorry took so long to get this info to you...was getting slammed at work this week and had to work late.
I don't know if these wire colors apply to your relay but I believe they are standard color schemes, it' like this on all the relays I buy.
color-pin-description
white-85-coil
black-86-coil
blue-30-switched
red-87a-normally closed
yellow-normally open
The yellow should go to directly to a fused 12v terminal on the battery
The blue would go to your lights
The white goes to a switched 12v source (your switch in this case)
The black goes to body ground
The red is not used
(the white and black can be interchanged)
If this does not look familiar let me know and we can figgure something out.
Old May 6, 2006 | 05:53 AM
aleok's Avatar
thanks, i had already fixed it though.
Mry
Mar 3, 2023 01:03 AM
bTanz
Oct 15, 2015 02:31 PM
Jiggerjuice
Aug 17, 2015 08:41 AM
Decimus141
Aug 13, 2015 08:42 AM
Detailed Image
Aug 10, 2015 02:29 PM
