clear bra tough to install
Old Apr 1, 2010 | 06:36 PM
johnw999's Avatar
So I bought a 3m clear bra precut kit from ebay. As expected, the bumper and headlights are difficult to install. The kit had 2 pieces for each headlight. I tried to install the left headlight cover, but I eventually had to give up. It wasn't coming together right, and the bra lost adhesive after I pulled it off a few times. I'll buy some more material and try again. Is it easier to do the headlight with a bulk strip and then trim the edges? Or, should I try again with the precut design?
Old Apr 1, 2010 | 07:23 PM
GEE35FX's Avatar
Much easier to get it professionally installed along with a quality job.
If they screw up, they fix it with their dollar.
Old Apr 1, 2010 | 07:28 PM
BloodlineG's Avatar
wayy to hard. but its expensive.
Old Apr 1, 2010 | 11:35 PM
johnw999's Avatar
Good news. I tried the passenger headlight, and I finally figured out the technique. It worked this time. I kept a copy of the pattern. So I'll order a small strip of 3m film, cut the pattern, and install the driver headlight.
Old Apr 1, 2010 | 11:51 PM
hybridamp's Avatar
Glad to read that you figured it out, I'm bad at applying adhesive stuff so I wouldn't even attempt this.
Old Apr 2, 2010 | 12:55 AM
tg1234's Avatar
Check youtube. There is agood installation on the second generation G.
Old Apr 2, 2010 | 07:28 AM
celwin's Avatar
You are learning what I did years ago, trying to install a clear bra yourself is a PITA and not worth it. I almost guarantee you'll F it up.
Old Apr 2, 2010 | 09:16 AM
InTgr8r's Avatar
Staff ALUMNI (retired)
definitely a tough DIY
I do a LOT of my own installs, but I wouldn't even consider doing clear bra.
Old Apr 2, 2010 | 09:29 AM
DPak07g35x's Avatar
clear bras are not that hard to do............. just need some good glass cleaner and a heat gun or a hair dryer.......... when u got the glass cleaner on the clear bra you should be able to move it around as needed and then just heat it up a bit when its in the postion you want
Old Apr 2, 2010 | 11:08 AM
LakeShore_Slate's Avatar
Whoa, good luck. Post some pics after your done.
Tolboothwilley™
Exterior-Vendor
Jul 28, 2016 12:42 AM
willdogs
Dec 8, 2015 11:32 AM
Mick_L
Aug 25, 2015 04:27 PM
Tylerttn
Jul 14, 2015 10:11 PM
