clear bra tough to install
So I bought a 3m clear bra precut kit from ebay. As expected, the bumper and headlights are difficult to install. The kit had 2 pieces for each headlight. I tried to install the left headlight cover, but I eventually had to give up. It wasn't coming together right, and the bra lost adhesive after I pulled it off a few times. I'll buy some more material and try again. Is it easier to do the headlight with a bulk strip and then trim the edges? Or, should I try again with the precut design?
Good news. I tried the passenger headlight, and I finally figured out the technique. It worked this time. I kept a copy of the pattern. So I'll order a small strip of 3m film, cut the pattern, and install the driver headlight.
You are learning what I did years ago, trying to install a clear bra yourself is a PITA and not worth it. I almost guarantee you'll F it up.
clear bras are not that hard to do............. just need some good glass cleaner and a heat gun or a hair dryer.......... when u got the glass cleaner on the clear bra you should be able to move it around as needed and then just heat it up a bit when its in the postion you want
Tolboothwilley™
Exterior-Vendor
Jul 28, 2016 12:42 AM
Mick_L
Aug 25, 2015 04:27 PM
07, 3m, bra, bulk, clear, clearbra, difficult, diy, easy, g35, infiniti, install, installation, installing, profesionaly
