Difference bettween v36 g35 and g37 navi system
Old Apr 1, 2014 | 01:44 AM
Speeddemon15026's Avatar
what is the difference between the v36 g35 and 37 navigation system / UI and is there any way to make the g35's like theirs (ie more stream lined look and feel and better graphics)? does it come with the map upgrade???
Old Apr 1, 2014 | 02:21 AM
Hotdawwgman's Avatar
2010+ got clearer display but the processor was never updated, so it's slower than the 07-09's...
Old Apr 1, 2014 | 02:26 AM
so could you retrofit one into a 35??
Old Apr 1, 2014 | 10:45 AM
Anything is possible... Just how much will it cost?
Old Apr 1, 2014 | 10:53 AM
WhosUrBuddiee's Avatar
There is alot different. Anything is possible with enough money. Odds are you lack the knowledge and money to pull it off.
Old Apr 1, 2014 | 01:29 PM
stockae92's Avatar
You can still update the map on '07 - '08 navi which is about $150 I think.
There are a lot of things needed to be changed if you want to do the swap, and you have to do your whole wiring. I think I have some DYI thread somewhere ...
Old Apr 1, 2014 | 01:33 PM
willdogs's Avatar
Not worth it. All the hundreds (or thousands) of dollars it will cost can be used elsewhere on the car.
Old Apr 1, 2014 | 10:44 PM
equifire's Avatar
At least one advantage for our hard drive based Navi system is that its faster than DVD.
Old Apr 2, 2014 | 02:41 PM
Rider14's Avatar
G35x
Navigation update for our 2008 G35's is $99 for the update code, and $140 for the install...one hour labor charge.
$240 is a bit much.
- Dan
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
laksjd84
Jul 24, 2015 05:12 PM
MrKrabs
Jul 23, 2015 05:41 AM
