Difference bettween v36 g35 and g37 navi system
Apr 1, 2014 | 01:44 AM
what is the difference between the v36 g35 and 37 navigation system / UI and is there any way to make the g35's like theirs (ie more stream lined look and feel and better graphics)? does it come with the map upgrade???
Reply 0
Apr 1, 2014 | 02:21 AM
2010+ got clearer display but the processor was never updated, so it's slower than the 07-09's...
Reply 0
Apr 1, 2014 | 02:26 AM
so could you retrofit one into a 35??
Reply 0
Apr 1, 2014 | 10:45 AM
Anything is possible... Just how much will it cost?
Reply 0
Apr 1, 2014 | 10:53 AM
There is alot different. Anything is possible with enough money. Odds are you lack the knowledge and money to pull it off.
Reply 0
Apr 1, 2014 | 01:29 PM
You can still update the map on '07 - '08 navi which is about $150 I think.
There are a lot of things needed to be changed if you want to do the swap, and you have to do your whole wiring. I think I have some DYI thread somewhere ...
Reply 0
Apr 1, 2014 | 01:33 PM
Not worth it. All the hundreds (or thousands) of dollars it will cost can be used elsewhere on the car.
Reply 0
Apr 1, 2014 | 10:44 PM
At least one advantage for our hard drive based Navi system is that its faster than DVD.
Reply 0
Apr 2, 2014 | 02:41 PM
Navigation update for our 2008 G35's is $99 for the update code, and $140 for the install...one hour labor charge.
$240 is a bit much.
- Dan
Reply 0
