I-Key works intermittenly even in port
Old May 21, 2014 | 01:15 PM
CodyE's Avatar
For the past couple of weeks every morning when I try to start my 07 G35 I have to keep hitting the start button for five to ten minutes before the I-Key is sensed and the car starts. The dash display gives the message no key and when I place it in the port it displays a symbol to remove it.
It will eventually start and it does not seem to matter rather the I-Key is in the port or not. When I go to start my car later in the day it will usually start on the first try about 90% of the time. I have also noticed that the manual key will not work when the I-key is not working. The fob has over 50% battery per the dash display and I have this problem with both I-keys.
I would appreciate any help in case there is a known simple fix before I take it to the dealership.
Old May 21, 2014 | 04:24 PM
markc's Avatar
The batteries in my 2 I-keys are 3 volt. When I brought the car out this spring they both worked intermittently. I popped the covers open and checked the battery voltage. Both read around 2.85 volts. Not really thinking this was the problem, I bought new batteries for $6 each and voila! Both I-keys now work perfect. Might be worth a try.
Old May 21, 2014 | 08:00 PM
silverG2007's Avatar
Yeah, I'd just start with the easiest/cheapest solution first: change the battery.
Or use your spare key?
Also, out of curiosity though, where does the dash tell you what % your ikey battery is?
Old May 22, 2014 | 02:53 PM
terrycs's Avatar
Save yourself a trip to the dealer.
Your ikey battery is dead. The display in the dash is only an icon so it doesn't really show battery level. If it is on, you should change the battery.
Old May 23, 2014 | 11:25 AM
CodyE's Avatar
Thanks everybody for the responses. Put a new battery in and it started this morning with no problem. Still don't understand why it worked intermittently when I put the I-key in the port as I understand it that should work with a dead battery.
Silver G2007, on the display that shows gph, miles remaining etc. I believe It only shows briefly after you start the car and only if the battery is below a certain level. Also, my manual key was not working to unlock the car. Think I may have a separate issue with the port and manual key.
Old May 23, 2014 | 11:27 PM
I've seen the "low battery" display. I'm just not sure how you saw "over 50% per the dash display."
Either way, glad you got it figured out.
And from what I've read, the I-key port works with a low battery, just not a completely dead one.
arora_g35
Apr 16, 2026 02:52 PM
carid
Group Buys-Vendor
Aug 7, 2015 12:17 PM
Cacoepy
Aug 3, 2015 01:09 PM
lemmy999
Jul 25, 2015 12:13 PM
beevanhuynh
Jul 14, 2015 09:06 AM
