DigitalWheelz Stealth Carputer Case
Old Nov 17, 2005 | 02:03 PM
god_of_cpu's Avatar
StreetDeck.com Developer
The DigitalWheelz stealth carputer case was just sent off to manufacturing. It will fit inside the empty space within the G35 spare tire. It should be very simple to install and remove without tools and will be invisible when not in use, covered by the trunk floor.
The entire case will be powered coated with a matte black finish.
It was designed around the standard 17" spare tire. It will NOT work with fullsize spares.
I am not sure about compatibility with spare tires for G35s equipped with 18" or larger wheels. If anyone knows if there are differences in the steel rims for the spares for different size wheels please reply to this thread. If there are differences, an 18" version will probably be made.
The final cost and options have not been determined. The case alone should be < $100. A complete system will probably be released around this case including everything needed to install a full carputer system including all hardware, software, and wiring. There won't be any more specific information on the bundle until its released.
The case should be available for purchase in January 2006.
More information here:
http://www.digitalwheelz.com/UbiquityV_About.htm
Old Nov 17, 2005 | 02:48 PM
codeflux's Avatar
that's friggin brilliant! thumbs-up!!!
Old Nov 17, 2005 | 02:59 PM
Espresso's Avatar
Sweet case mounts but one issue for the one that goes in the spare tire. Once it's under the floor board, will there be any air circulation? I know there's vents in the trunk but there won't be a way to get that air into the spare tire unless you drill holes in the floor board. I'm sure you have a plan for that but it's just a thought.
Old Nov 17, 2005 | 03:25 PM
amthar's Avatar
Sounds like he does not recommend running the PC with the trunk floor over it?
Old Nov 17, 2005 | 04:03 PM
god_of_cpu's Avatar
There is about an inch or so between the surface of the tire and the floor as well as a fan in the case that will circulate air from the processor. The case is more or less an open design using the whole bottom area of the trunk. I don't think theres any good mounting place in the car that will have real good air circulation, but I haven't found mounting in the spare tire to be any worse then anyplace else in the trunk and in any case I think it should be quite adequate for a VIA ITX or Pentium M.
Old Nov 17, 2005 | 04:05 PM
god_of_cpu's Avatar
No its designed to run with the floor over it.
Old Nov 17, 2005 | 09:20 PM
caelric's Avatar
Bah! I just want my 2005 digitalwheelz screen to be finished so I can buy one from you!
Dave
Old Nov 18, 2005 | 09:35 AM
steviep_g35's Avatar
Do you have a notification list going for the release of the 05 lcd screen housing and now for this carputer housing? Because I definitely want to be in the "know" when these items hit the "market!" Very excited about these two products.
Old Nov 18, 2005 | 11:53 AM
smedly's Avatar
same here i want the 2005 housing for nav.
Old Nov 18, 2005 | 11:58 AM
gizsf's Avatar
It may be a good and inexpensive idea to put a little bit of rubber matting in points where it is contacting with the vehicle or wheel to cut down on vibrations too.
Old Nov 18, 2005 | 02:05 PM
god_of_cpu's Avatar
This is already planned. The edges of the bottom piece will be covered in rubber tubing.
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
suby01
Not G35 Related
May 25, 2016 03:07 PM
f22raptor
Mar 18, 2016 08:50 AM
Duffy25
Accessories
Oct 12, 2015 01:45 AM
