Opinion: Popcharger vs. Stillen High Flow.
Old Jun 16, 2006 | 08:39 PM
skc's Avatar
skc
Currently I just have the Z tube with the k&n drop-in. Looking to upgrade. What are the advantages/disadvantages between the popcharger and the stillen high flow intake sys?
Old Jun 17, 2006 | 12:44 AM
g35cas's Avatar
They are almost the exact same set up. The stillen gets a little more cold air than the pop-charger(stillen has better heat shield). The pop-charger is a little louder than the stillen(again, the heat shield). My cousin is running the pop-charger in his z, he loves it. I have the stillen in my G, and love it. So you can't go wrong either way. The stillen is about $100 more expensive than the pop-charger. So if money is your deciding factor, go with the pop-charger. If your worried about hot engine air and want a better heat shield, go with stillen.
Old Jun 17, 2006 | 01:59 AM
EricIsKlumzyee's Avatar
PopCharger = Better Filter w/****ty Heat Shield
Stillen = Cone Filter in a Box
PopCharger w/Stillen.. now u have something
Old Jun 17, 2006 | 03:33 PM
skc's Avatar
skc
what would the stillen + pop look like? anyone here with that setup?
Old Jun 17, 2006 | 03:46 PM
g35rcr's Avatar
yes you can combine the heat shield from stillen with a pop filter
Old Jun 17, 2006 | 04:50 PM
skc's Avatar
skc
yeah, maybe ill do the stillen hfab with the pop charger filter... that seems cool
thanks all for the help
Old Jun 17, 2006 | 07:04 PM
just buy a stillen and run it.. and when a good priced popcharger then get it so you'll have two filters
Old Jun 17, 2006 | 07:26 PM
gary c's Avatar
Go.........Stillen!
I'm running the Stillen CAI along with other related
mods and wouldn't change a thing. Everything G35
will give you a good price on the CAI they are one of
our sponsors......
Old Jun 18, 2006 | 12:05 AM
Klubbheads's Avatar
+1~!
Old Jun 18, 2006 | 01:13 AM
GeeMan's Avatar
Get the Stillen if you're in hot climes most of the time (e.g. Cali or FL) else get the pop charger. Stillen is slightly better at protecting against engine heated air when compared to the pop charger. Pretty much a wash however on any actual performance increase between the two. you can't go wrong, or is that right?
Old Jun 18, 2006 | 03:23 AM
richboy's Avatar
MORE POWER PLZ!!!
I was also wondering if anyone here tried the Stillen w/ PC combo?
Old Jun 18, 2006 | 12:38 PM
Andy2434's Avatar
I have been wanting to try this for months, now. I just never got around to it. I believe that DaveO has this very same set-up and he is quite pleased with it.
Old Jun 18, 2006 | 01:18 PM
godmans's Avatar
Just get the stillen, I think it alone is good enough and is best bang for the buck
Old Jun 19, 2006 | 01:52 AM
truplay8's Avatar
THE BATMOBILE
stillen do it
Old Jun 21, 2006 | 12:05 PM
lightforce18's Avatar
the heat shield on the pop charger is a POS. get the stillen
