Installed: MD 5/16 w/Iso Thermal kit & Z-tube
Old Jun 24, 2006 | 12:30 PM
dTor's Avatar
Thumbs up Installed: MD 5/16 w/Iso Thermal kit & Z-tube
The Butt Dyno is pleased
I installed these items yesteday. It took me about 3 hours, but I cleaned the bejesus out of the engine compartment too, plus my halogen work light blew so I had to use a flashlight when I was putting it all back together.
Everything turned out great though. No stripped threads or broken bolts, nothing fell into the engine, and I even remembered to put loctite on the bolts BEFORE I started tightening them down.
Further, I did the EASY ECU reset (i.e. disconnect the negative battery cable while I was cleaning up ), then did the TPS zero throttle reset, fired that beeotch up, and didn't get a single code on the hour long test drive I took.
I also cleaned up the carbon buildup around the TB butterfly which is just good maintenance.
The only issue I had was with the fitment of the Z tube. It doesn't seem to fit exactly like the OEM tube does. It's kinda stretched out a bit at the accordian. When I tighted the clamp to the back of the MAF sensor, I actually noticed a small tear! Fortunately, it didn't seem too deep, but I packed some black RTV silicone sealant in there just in case.
The engine growls a little more now throughout the RPM range. At WOT, it is very pleasingly louder & meaner sounding than stock.
I cannot wait until I get the Topspeed headers (which currently reside in a box in my office - Thank you PhxBlue!!) installed. I was going to wait until next weekend, but I'm not sure if I can make it that long. :toetap:
Anyway, I'm about to run up to IHOP and fetch breakfast for the wife and I. I'm sure it'll be fun.
Old Jun 24, 2006 | 12:36 PM
RBull's Avatar
Rated M
Nice write up.
I like my spacer too.
G/L
Old Jun 24, 2006 | 12:38 PM
Down_Shift's Avatar
TPS Zero Throttle Reset? What's that
Old Jun 24, 2006 | 02:18 PM
dTor's Avatar
If you mess with the butterfly on the throttle body (how else are you supposed to clean behind it??), the "highly sensitive, calibrated electronic sensors" can get knocked outta whack. So that the ECU knows what zero throttle input is, you have to tell it, through this procedure, what zero throttle is. Remember, this is a drive-by-wire throttle, i.e. no throttle cable from the pedal to the TB.
All you do is ensure that the gas pedal is not depressed (that poor, poor, pedal - maybe we could give it some Prozac ) turn the key to "ON" for at least 2 seconds, turn it "OFF" for at least 10, then repeat. Now your car knows when you are not applying any throttle.
Old Jun 24, 2006 | 02:26 PM
dTor's Avatar
Oh yeah, I reinstalled the Power Duct.
https://g35driver.com/forums/intake-exhaust/104383-when-people-refer-removing-power-duct.html
Old Jul 2, 2006 | 01:07 AM
dTor's Avatar
So I'm a week into having the spacer and tube installed and I'm happier with them now than when I put them on. I am all whenever I'm driving my car and especially when I romp on the throttle a little. If all goes according to plan, I'll be installing the headers on Monday by myself (case of beer goes to whoever wants to help ). I'll let y'all know how that goes.
Old Jul 2, 2006 | 02:51 AM
99atlantic's Avatar
https://g35driver.com/forums/showthread.php?t=104383
your ***** will shrink from the reinstallation
^_^
Old Jul 2, 2006 | 02:02 PM
truplay8's Avatar
THE BATMOBILE
nice write up.......glad to hear you like it
Old Jul 2, 2006 | 03:42 PM
liquidrage's Avatar
For a case of beer we got a nice garage you can use if you want to make the long drive to Tallahassee
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
linedr89
Engine - Power Adders
Oct 4, 2015 07:29 PM
G35-2004-mt6
Sep 11, 2015 04:16 PM
JG_G35
Engine - Intake/Fuel
Sep 7, 2015 09:35 PM
