Need for cutting exhaust?
Old Sep 29, 2003 | 02:24 AM
NismoV35's Avatar
From: Los Angeles, National Socialist Democratic Republic of Facistfornia
Re: Need for cutting exhaust?
Naw, No cutting is necessary. It will Un bolt in 3 sections The front Y Pipe, The Middle section with Resonator, and the Muffler section. Remember to save the Small Round Ring Gasket. It's not too difficult to install. You can do it if you have a Floor Jack and jack stands. That and a Good Socket set, Oh A Breaker bar helps make it easy to get the Bolts off.. Good Luck!
I'm Just A Simple Man, Trying to Make My Way Through The Universe......."JangoFett"
NismoCPV-35
Old Sep 29, 2003 | 02:51 AM
1nate7's Avatar
I did it with just ramps and while it wasn't that easy it was that bad either. I'm not the most mechanical person BTW but I didn't have any problems. It really speeds things up to have a second person helping. The second person is especially helpful when removing the muffler section, they can support the weight and pull back while you remove the rubber hangers. Some WD-40 helps free the exhaust from the rubber hangers as well.
It worked best for me to start toward the front at the cats and go back toward the muffler. If you start with the muffler you will not have enough play in the system to fit the the last pieces in. Also, make sure you slide a clamp on each section before connecting. This sounds obvious but there are a lot of clamps and I left one off by accident and had to go back and take it all apart to get the clamp on. If you have any more questions just let me know and I will try to help.
Old Sep 29, 2003 | 10:31 AM
townsley's Avatar
That G is gonna sound sweet! Where did you get your Borla and how much did you pay?
-townsley-
2003 Brilliant Silver Premium Sedan
Z Inlet, K&N Filter, Tinted, Grounded
Old Sep 29, 2003 | 08:56 PM
wjfm1's Avatar
Do you have the website?
2003.5 G35C BL/GR, NAV, PREM, AERO, TINT, SPORT, Valentine 1
Old Sep 29, 2003 | 09:11 PM
1nate7's Avatar
See if you can get ahold of Brett Labree at Labree Motorsports. I don't have his number but there is a thread (the borla group buy) that should have it in there. Its been a while so they might all be gone, but last I heard he had three left. I don't think I am supposed to quote prices on here, but it is significantly less than $750.
Old Sep 30, 2003 | 12:23 PM
Msedanman's Avatar
O.F. Administrator
MNDZA. No cutting bro. As a matter of fact I saved my stock exhaust and attached a pic.
You can see the 2 flanges in the pic: One just behind the muffler, and the other between the 'Y' pipe and the resonator.
Mine was up on a hoist to do the removal and install. Not sure on how it would go on the ground. Good luck.
<font color=red>GSM</font color=red> <font color=black>Silverstone Coupe</font color=black>
Old Sep 30, 2003 | 11:55 PM
RamboRami's Avatar
G35driver.com Moderator
MNDZA, i installed the exhaust w/ a friend in his driveway, we used 18" rhino plastic ramps to hoist up the rear.
It took about 2-3 hours, but thats because we had a rain delay and power outage that day.
Basically, the stock bolts are on VERY VERY tight. So you need to kick the socket wrench with your foot in order to break loose the bolts if you are using the ramp method.
However if you are hoisting your car up at a shop, then you will need a breaker bar (or any hollow metal bar) so you can get good leverage on that socket wrench.
G35c 6MT DG/Willow/HyperGround/BorlaExhaust
Thebaws11
Jul 2, 2021 11:36 AM
gatorglaze
Sep 19, 2015 12:06 PM
JustinMKN1
Sep 18, 2015 03:40 PM
Albanian122
Sep 12, 2015 04:02 PM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
