MREV+ vs MREV2: Dynos Inside
Old Jul 9, 2006 | 07:49 PM
BocaCoupe's Avatar
G's Up, Ho's Down
Revup MREV+ vs MREV2: Dynos Inside (both with 5/16th spacer)
EDIT: This is a REVUP
I decided to see if the MREV2 did indeed show an improvement over the MREV+ that I had installed.
The MREV2 arrived from Tony well packaged and I noticed additional machining over the MREV+.
I did have some aluminum dust from machining which I cleaned off using soap/water and drying immediately.
The swap was performed on the dyno per Tony's request and the engine temps were kept the same.
After doing the swap around 5 times, I had no trouble exchanging the lower plenum.
I did a total of 6 runs, 3 before, 3 after, with an ECU reset (pedal method) before the 1st 3, and the last 3.
I would like to mention that the run was done until the engine hit the rev-limiter so the last 500rpm or so drop off is really outside the normal operating RPMs.
In terms of the "Butt Dyno" I do see improvement around the midrange-topend.
It pulls to the top harder than before. I highly recommned this upgrade to anyone looking for more NA power.
P.S. Yes I know one of the plenum spacers was not installed when taking the picture.
Rob Dyno Video
Here are some of the Dyno's for you to check out:
Attached Thumbnails MREV+ vs MREV2: Dynos Inside-allsix.jpg   MREV+ vs MREV2: Dynos Inside-max259.jpg   MREV+ vs MREV2: Dynos Inside-max261.jpg   MREV+ vs MREV2: Dynos Inside-261afr.jpg
Old Jul 9, 2006 | 08:07 PM
kia's Avatar
kia
sikc video mang.......
Old Jul 9, 2006 | 08:10 PM
RBull's Avatar
Rated M
Thanks for posting. Very consistent pulls with a slight edge to the MREV2 in the mid and top ranges.
Old Jul 9, 2006 | 08:46 PM
truplay8's Avatar
THE BATMOBILE
great vid rob........great numbers also.........who did the dyno, and how much was it???? admins should sticky this thread
Old Jul 9, 2006 | 08:56 PM
BocaCoupe's Avatar
G's Up, Ho's Down
Dyno's were done by Billet Design Motorsports in Pompano Beach.
Old Jul 9, 2006 | 09:39 PM
Andy2434's Avatar
Sweet! Nice job. I still have to get mine done.
Old Jul 10, 2006 | 03:01 AM
richie's Avatar
yup... mrev2 does kick some butt
it was a great experience working with Motordyne/Tony... if only other companies offered that kind of customer service
Old Jul 10, 2006 | 06:36 AM
RebelinRI's Avatar
Great post!!!! This is what forums should be like!!! Proof!!! Not hype!!! Anyone want to sell there MREV+ PM me. Yes MREV+ not MREV2. I want to try something. Great Job Rob
Old Jul 10, 2006 | 07:37 AM
speeddreamz's Avatar
any sort of engine management? Im worried about doing both spacer and mrev2 without any sort....
Old Jul 10, 2006 | 11:07 AM
LMG_35C's Avatar
^ +1
Great job, and thanks for posting dyno's.
Am I reading the A/F chart correctly that the Mrev2 actually improved the A/F ratio slightly?
No Dyno here but my 2004 MT Coupe with Mrev2 added after 3/8" spacer is stronger in mid-range pulls..
Old Jul 10, 2006 | 02:21 PM
BocaCoupe's Avatar
G's Up, Ho's Down
I'm not technical enough to decipher the AFR. Anyone can shed some light on it?
Old Jul 10, 2006 | 05:14 PM
Originally Posted by LMG_35C
^ +1
Although it pulls harder, sometimes slightly leaner = more power, its just that in the wrong condition or just a little bit too much WOT will make you start knocking...
No engine management for you?
coming from a turbo car, I would only run in the 13's, high 13's I guess would be OK, but Its pushing it from 5800-6800 the A/F slightly worries me. I know that the dyno runs richer correct? Theres less load on the car right? I don't know about non turbo but it would worry me sorta.
Higher number = leaner. So 14-15 is leaning out. not super lean, but under WOT u probably don't want that. Under 12 is rich.
seagrasser
May 3, 2022 09:43 AM
Marlin84
Apr 1, 2020 12:52 PM
jeffbdye
Jun 1, 2018 03:51 PM
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
vQFamily
Sep 30, 2015 01:17 PM
