Full Exhaust question !
Old Jul 22, 2006 | 10:09 PM
MikeIvoryg35's Avatar
Just wondering what exactly makes up our cars full exhaust system??? cuz right now i just have a greddy sp2 exhaust. so is that just the 'cat-back'? If i was to upgrade full exhaust i would need headers, test/race/y pipes and a midpipe??? is true dual exhaust better? Basically i just want to upgrade performance without goin FI.Thanks guys
Old Jul 22, 2006 | 10:13 PM
diablo1356's Avatar
im no expert on FI..but from what ive read on these boards it seems that true dual is a better setup for FI...someone correct me if im wrong please..and as for the cat back exhaust the greddy sp2 is just what it says it is...from the catalytic converters to the end of the exhaust..thats all you are replacing...to do the "full" exhaust i believe you would need to start with headers, then test pipes/high flow cats/then the cat back exhaust...true dual setups tend to take away low end power in favor of some top end gain and a different sound...
Old Jul 22, 2006 | 10:19 PM
M4Gunner's Avatar
naturally a true dual would be better because it will breath easier. the "cat-back" means that the mid-pipe is included, so you wont need that. im not sure if the SP2 includes a Y pipe, but lets assume it doesnt. you'd need headers, test/hi-flo, and a Y pipe. attatch that to your SP2 and you have a full exhaust.
OR... start over and go with a true dual, and that way you dont have to buy a Y pipe either! is the performance difference going to be worth the money?? im not sure, someone else will have to help you there. but i would suspect it wouldnt make THAT much of a difference.
Old Jul 22, 2006 | 11:38 PM
drunkin master's Avatar
I have the greddy sp2 and it is an axle back (only the muffler). If you want to go with a full exhaust it will have everything after the cats. Y pipe or h pipe depending if you go true dual or not. You should do a search and find out what people that are going with tt or sc are using.
Old Jul 23, 2006 | 12:35 AM
IvoryGT's Avatar
a good place to start is looking for ones similar to the Nismo weldina, it includes everything beyond the cats, so Y pipe + mid-pipe + muffler = full exhaust.
When you start getting headers and test pipe or highflows you are treading in thin water with drivability and noise. Basically without FI you want to retain the backpressure for low end torque, if you go true dual and test pipe you will lose that in exchange for high end power like top speed run.
Old Jul 23, 2006 | 02:17 AM
ISMSOLUTIONS's Avatar
Testpipes and high flow CATS do nothing to change driveability, and just about nothing to loose low end torque.
Low end torque losses are more likely seen with headers added to the mix.
Our true dual losses low end torque from 2100-2200 RPM, the lowest range in the industry from what we have seen on dyno's and our R&D. You can see our system and dyno's, clips and pics at the site at http://2www.fastintentions.com.
You can also check a number of reviews on this board from members who have installed the system as well.
We also have a GB going on now for our high flow CATS.
Feel free to PM me or ask questions on this thread if you like - or search out the other threads for answers...they are out there.
Rick
Muski_G
Dec 1, 2023 11:11 AM
Th611
Oct 27, 2015 03:48 PM
Shizzmaster2k
Engine - Exhaust
11
Sep 2, 2015 04:09 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
Cskeet
Jul 19, 2015 12:38 AM
