how to gain low end?
Old Aug 10, 2006 | 05:55 PM
meat's Avatar
so when you put on an aftermarket exhaust and you end up losing a little bit of the low end. What are some bolt-on mods you could do to get back it back and even get some gains in low-end. I don't want togo with FI. Sorry if this is a rookie question. Thanks in advance for help.
Eric
Old Aug 11, 2006 | 02:16 AM
jasonlee4180's Avatar
Try a UR underdrive pulley, that's a start. Other than that, I don't think there's much you can do for your lowend.
If you've got a good exhaust, which it looks like you do, you recover your lost tq earlier in your rpm band so it shouldn't be as noticeable. Just drive it no less than 4k rpm everywhere you go
Old Aug 11, 2006 | 03:22 AM
Calvin's Avatar
Overglorified Altima
you should only lose low end torque when going aftermarket true dual exhausts..if you stay away from those you should be fine in the low end
but with the true duals youll gain it all back and more in the end..
Old Aug 11, 2006 | 03:27 PM
G-Tofu's Avatar
Pulley is amazing at 2rd gear......
Old Aug 11, 2006 | 07:19 PM
TURBOTOM's Avatar
a.k.a kleicoupe
do you actually notice a difference with pullies??
Old Aug 13, 2006 | 06:06 PM
G-Tofu's Avatar
^^^yup......
Old Aug 13, 2006 | 06:30 PM
codeflux's Avatar
pullies = 0.1 second gained in the 1/4 mile.
Old Aug 13, 2006 | 10:48 PM
636Racer's Avatar
change your final drive ring and pinion. probably the most expensive (runner up to FI), but probably the most noticable.
ttrank's Avatar
Grocery getter
Stillen SC will give you all the low end you can use and more.
StreetStandard
Engine-Vendor
117
May 22, 2020 08:21 AM
Kng0fHrts
Sep 15, 2015 05:40 PM
