HELP!!!! y-pipe question
Old Aug 19, 2006 | 05:52 PM
LIUser's Avatar
can the y-pipe be installed without taking out the midpipe and muffler?
i just got my fuji y-pipe and exhaust and i cant get the y-pipe off. if i installed the midpipe and muffler would an exhaust shop be able to put just the y-pipe on for a little less than what they wanted, or do they still need to take off the other ****?
Old Aug 19, 2006 | 06:03 PM
GReddySetGO's Avatar
You can do the Y-pipe later. It can be disconnected from everything else and installed on its own. How come you cant get the stock one off?
Old Aug 19, 2006 | 06:07 PM
LIUser's Avatar
i cant get enough leverage on it and the nuts wont come off... it started stripping the nut when i hit it with a hammer
thanks for the reply!!!
Old Aug 19, 2006 | 06:40 PM
g35rcr's Avatar
try some antiseize and let it cool down...worst case take it to an exhaust shop
Old Aug 19, 2006 | 06:58 PM
gary c's Avatar
Y...........not?
WD-40 and let it cool down overnight....remove the
rear flange and pop out with a large screwdriver.
Then loosen the flanges on the cats and remove trying not to damage the gaskets. These are not
normal gaskets due to the extra heat there subjected
to. Don't ya hate laying on your back working
over head....I usually pay a buddy to use his lift
for things like this for like $10. LOL
Old Aug 19, 2006 | 10:42 PM
LIUser's Avatar
hehe, ya im taking it to an exhaust shop to do, working on ur back sucks and i think they may have to saw one off cuz it got kind of worn down from me
to all of u, i did wd40 it and let it sit for about 30 mins, is that not long enough???
anyways, i installed hte z-tube, pop charger, and fuji exhaust. cant wait to hear it with the y-pipe, sounds great right now.
honestly, no noticeable power increases, a little more responsive and sounds GORGEOUS!!! by no means abnoxiously loud, but louder than stock, love it. very very very little to no rasp with this setup.
WOT above 3.5k =
Old Aug 21, 2006 | 12:36 AM
spudly's Avatar
pb blaster and impact sockets. They won't round things off when you have to resort to brute force.
Old Aug 21, 2006 | 03:33 PM
I don't use rachets/sockets for breaking nuts loose. Use WD40 or similar and let it soak for a few mins, then use a close ended wrench to break it loose. Then you can use a rachet or air afterwards.
Old Aug 21, 2006 | 03:48 PM
V35 Skyline GT's Avatar
6MT Coupe
Just be sure to use a 6 point whatever you use.
Don't use a 12 point. That's what rounds off the flats on the nut.
Old Aug 21, 2006 | 05:07 PM
^ w3rd. Good point I forgot to mention. 12pt is ok after its loose and you're using a rachet, but the initial turn to break it loose should be done with a 6pt.
Old Aug 22, 2006 | 01:38 PM
LIUser's Avatar
finally got my y-pipe installed, the difference i notie... ABSOLUTELY NOTHING!!!!
oh well, the experience of putting on my y-pipe was still fun, a shop actually let me use their tools and lift
Machine Head
19 Inch
Mar 16, 2016 08:55 PM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
kevintandmd
Sep 3, 2015 06:41 PM
UT G35
Sep 3, 2015 03:58 PM
erich2780
Sep 3, 2015 03:23 PM
