for people with 5/16th spacers...
Old Aug 24, 2006 | 09:05 PM
cungkpham's Avatar
what was your reasoning for buying the 5/16th spacer rather than the 1/2 inch??? dumb topic, but i just want to know. because it almost seems like im the only one in here with 1/2inch
Garyv01's Avatar
because with 1/2 inch MD says u cant put the stock engine cover back on
Old Aug 24, 2006 | 09:55 PM
jjyellow's Avatar
I recently got the 1/2 spacer on mines and got the cover back on!!
Old Aug 24, 2006 | 10:06 PM
Andy2434's Avatar
The 5/16" spacer worked best with the MREV+ for the RevUp engines.
Old Aug 25, 2006 | 01:29 PM
ballisticus's Avatar
I have the 1/2" and think the engine looks better without that cheap looking plastic cover. If you paint or powdercoat the plenum it looks good and you should get a cooler air charge too without the cover trapping the heat under it.
Old Aug 26, 2006 | 10:58 AM
LMG_35C's Avatar
More mid-range gains for the 5/16 but the 1/2 sacrifices that for a bit more top end that would further benefit from raising rev limiter, and I'm sure some tunable EMU or reflash.
As above I've heard a lot of people say that could get they engine cover on with the 1/2 by reversing the grommets.
Either one is worth the money. Would suggest the ISO Thermal lower plenum gasket and Throttle Body copper isolation gasket as well.
I added the MREV2 recently, despite claims of lean AF on 04's. I feel the difference with all of these were worth the time and money. Got em on the original group buys though..
Old Aug 26, 2006 | 02:41 PM
DaveB's Avatar
Because there is hardly any difference in performance between the two and the 1/2" spacer trades a bit midrange for topend power. Midrange power is far more benefical to acceleration.
Old Aug 26, 2006 | 03:28 PM
g35rcr's Avatar
if you are driving your car at 6k rpm constantly then get the 1/2 spacer, but i doubt you rev your car that high every shift and maintain there
Old Aug 27, 2006 | 03:00 AM
Calvin's Avatar
Overglorified Altima
i wanted to put the stock engine cover back on and from what ive read youll gain throughout rather than just up top
Old Aug 28, 2006 | 01:25 AM
dTor's Avatar
I got the 5/16 MD because I wanted to have power that I could actually use instead of just talk about. My car rarely sees 5K+ RPMs, so why would I want an extra 2 or 3 hp up top and not as much to show for it in a useable range?
Old Aug 28, 2006 | 08:34 AM
JEVERYDAY's Avatar
+11
Old Sep 5, 2006 | 12:44 PM
SFG356MT's Avatar
^^^+12 Just to have the option to put the cover back on.
Old Sep 5, 2006 | 02:53 PM
driguez's Avatar
im running the 5/8" you are not alone
Rose M
Oct 12, 2015 10:00 AM
TurTLe*
Sep 29, 2015 01:43 PM
